clunk noise of hard turns tein cs spc camber
Old May 27, 2008 | 05:46 PM
tightvpkid's Avatar
I have tein cs coilovers with spc camber and toe. Every time i take a hard right or left turn and hit a bump( difference in road ) the cars makes a loud climp noise. Whats going on? sounds like something is rubbing when i take a hard turn awhen i say uneven surface i mean a very minor one not a huge one like a little uneven surface road that are very common. any thought what the noise can be? its doing it on a sharp right and left turn...sounds like something is colliding during the turn....quick CLunk..
-Jimmy-
Old May 29, 2008 | 01:31 AM
tightvpkid's Avatar
no one..?
Old May 29, 2008 | 01:55 AM
WACK BEATS's Avatar
make sure everything is bolted up nice and tight. Do you have after market sway bars? My hotchkis sways clunked around a little when i turned because one side wasn't tight enough.
Old May 29, 2008 | 02:12 AM
ben0878's Avatar
Any more info is it coming from the front or the rear? It could be a number of things balljoints, shock mounts, swaybar end links, motor mounts ect.
Old May 29, 2008 | 02:40 AM
1g35fan's Avatar
I have tein CS coilovers too and hear a clicking sound coming from my drivers side rear. I thought it was the parking brake at first and had it checked and adjusted but the clicking noise continues. I now think it might be the axle. I only hear the noise while making right hand turns. Very annoying sound.
Old May 29, 2008 | 05:23 PM
monkey's Avatar
Clicking axles? Thats a TSB issue, not related to suspension... Might be worth checking out.
Old May 29, 2008 | 07:54 PM
lniivedl's Avatar
Do you have the spc upper control arms?
Really not sure but heard lots of people having problems with them knocking.
Just throwing it out there..hope it helps.
Old May 29, 2008 | 08:13 PM
silvernole12's Avatar
the pillow ball mount maybe loosing some tolerances. try your stock shock on that side and see if the noise goes away.
Old May 31, 2008 | 03:22 AM
tightvpkid's Avatar
yea i have the spc upper control arm...i bought the A-arm and the rear toe. makes it only in the front...mines comes from the right and left...when making a hard turn and running over a little un even surface..but i don;t hear ne thing if the road is smooth. nice clean turn...and no i don;t have any sways yet...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
itztwinki3
Oct 5, 2015 11:29 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
cyrus32
Jul 18, 2015 06:22 PM
