Alignment and Upper A-arms Question?!?!
Old May 29, 2008 | 08:12 PM
lniivedl's Avatar
So I got my alignment redone at West Covina Nissan yesterday after having 350z Htechs for a few months..and came up with these specs for the front
Camber: Left: -1.7 Right: -2.0
Caster: Left: 8.8 Right: 8.7
Toe: Left: 0.05 Right: 0.04
Problem is I see some inner tire wear that I dont think is supposed to be there..but I'm not sure if it is considered comparable with stock suspension given the G's tires dont last long to begin with.
SO, wondering how necessary the upper control arms are at this point. I'll be flipping the tires soon but still dont wanna have to replace tires every year. I just do regular driving with ~65% highway with a little over 1k miles a month
Old May 30, 2008 | 03:22 PM
lniivedl's Avatar
bummmp
Old May 30, 2008 | 03:56 PM
redlude97's Avatar
that alignment looks fine, if you are getting alot of inner wear, then it would be a good idea to look at a-arms, you won't be able to adjust anything on the current suspension that will make that inner wear go away. I have the same problem because 85% of my driving is freeway, so inner wear is inevitable without camber correction
Old May 30, 2008 | 04:17 PM
lniivedl's Avatar
so that camber is pretty normal?
Redlude- so wat are ur specs and how many miles did your tires last you?
Old May 30, 2008 | 04:22 PM
redlude97's Avatar
pretty close to yours
Camber: -1.6L -1.9R
Toe: 0.04L 0.04R
I get inner tire wear too, just flipped my tires and I'll probably get 17k out of them
Old May 30, 2008 | 04:35 PM
lniivedl's Avatar
Whoa quick response lol
hmm the alignment guy said itll last for another 6 months and its been 6 months since the drop...12k for tires?!? not good imo...
so SPC vs SPL?
I'd like at least 1.0-1.5 degrees positive camber adjustability
Do people still have knocking/light problems with the revised SPC kits?
Old May 30, 2008 | 04:50 PM
redlude97's Avatar
1-1.5 degrees of positive adjust is too much IMO, you shouldn't need more than 1-1/2 degree of positive adjustment. Personally I would just purchase the cusco/ichiba a-arms which have ~1/2 degree of positive adjustment. Going much higher than that and handling performance is going to be negatively affected
Old May 30, 2008 | 05:21 PM
lniivedl's Avatar
oh i forgot to mention im planning on dropping it more later..so the cusco/ichiba with only 0.5 + camber wouldnt be enough..
unless you meant to get the cusco/ichiba regardless of the drop?
Old May 30, 2008 | 05:35 PM
redlude97's Avatar
I meant with the h-techs, they are the most cost effective choice for moderate drops
Old May 31, 2008 | 10:36 AM
lniivedl's Avatar
so u think the SPC's are good enough for the money compared to SPL?
Old May 31, 2008 | 11:53 AM
redlude97's Avatar
The only arms I would personally run are: cusco, spl, stillen, and 350evo
Old Jun 1, 2008 | 01:30 PM
lniivedl's Avatar
what camber up front am i looking at with the 350z stechs?
wondering now if the cusco/ichiba would be enough with those...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
j_mullet
Aug 26, 2015 10:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
itschuckster
Jul 25, 2015 08:07 AM
