oem brembo powder coating
Old Jun 16, 2008 | 10:45 AM
SleekStyle's Avatar
Red face oem brembo powder coating
hey just wondered if anyone has already done this? I have a few quesions. i noticed there are some allen bolts holding the caliper together and my question is how do i take apart the brakes so i can just give the powdercoater just the caliper. or what do i need to remove for this process.
thanks for any help
Old Jun 16, 2008 | 06:06 PM
Scrooge's Avatar
Its not hard to rebuild the calipers. First thing you have to do is take off the brake line that connect right at the caliper and plugs it up so no brake fluid leaks out and damages your brake line. After that remove the caliper from the steering knucle and then get a skin piece of wood and insert in between the pistonand then open one of the bleeder holes and blow compress air into it.
This would force the pistons out and then you can remove them. After that start taking apart tube that connects the capiler together and then take the remaining bolts apart.
Old Jun 16, 2008 | 06:09 PM
redlude97's Avatar
You actually shouldn't need to disassemble the caliper to PC them, calipers/pistons/seals should be able to take the 400deg baking used during the PC without too much trouble
Old Jun 16, 2008 | 06:10 PM
Scrooge's Avatar
Disassembly and Assembly
Disassembly and Assembly of Caliper Assembly
DISASSEMBLY
1. Insert a piece of wood as shown in the figure, blow air in through the flare nut mounting hole, and remove piston and piston boot. If four pistons do not all come out at the same time, press pistons that have come out a ways into cylinder body and blow air In again. CAUTION: Do not get your fingers caught in piston.
2. Remove piston boot from piston.
3. Using a screwdriver, remove piston seal. CAUTION:
o Be careful not to damage cylinder inner wall.
o Never remove four bolts from the inner and outer sides of caliper. Do not tighten them further, either.
CALIPER INSPECTION
Caliper
CAUTION: Use new brake fluid to clean. Never use mineral oils such as gasoline or kerosene.
* Check for corrosion, wear, or damage to the cylinder inner wall, and replace caliper if there are any nonstandard conditions.
Piston
CAUTION: Since the piston surface is plated, do not repair using sandpaper.
* Check piston surface for corrosion, wear, and damage. If any non-standard condition is detected, replace applicable part.
ASSEMBLY
CAUTION: Do not use Nissan Rubber Grease (KRE00 00010, KRE00 00010 01) when assembling.
1. Apply a rubber grease to piston seal and insert to cylinder body. CAUTION: Do not reuse piston seals.
2. Apply brake fluid or rubber grease to piston boot, place it on piston, and firmly insert the piston boot cylinder-side lip into the cylinder body groove. CAUTION: DO not reuse piston boot.
3. Insert the piston into cylinder body by hand and firmly attach the piston boot piston-side lip into the piston groove. CAUTION: Press the piston evenly and vary the pressing point to prevent cylinder inner wall from being rubbed
Old Jun 16, 2008 | 07:10 PM
High3nd_SD_g35's Avatar
hmmm powercoating brembos? sounds like a good idea....
Old Jun 17, 2008 | 06:19 AM
silvernole12's Avatar
I wouldn't remove the allen bolts that hold the two halves together. You can take out the pistons and the dust boots/seals though. But as redlude97 said, I've seen people get their's done without taking apart anything.
Old Jun 17, 2008 | 07:57 AM
Scrooge's Avatar
You sure you don't want to worry. Just an incase something happens. It is good to put new seals in.
Old Jun 17, 2008 | 02:17 PM
olgunan's Avatar
i have heard that if you send the calipers back to brembo they will do it for free and the only cost is the shipping! I could be wrong about this but it would be worth checking out in my mind!
Old Jun 17, 2008 | 05:36 PM
SleekStyle's Avatar
well i asked my guy at a local car shop and they said since they know a good friemd that works at brembo that they dont PC the calipers they just shoot paint on them and clear then after the sticker has applied.
i will post pics of the final product tonight btw
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Raiderpolo15
18 Inch
11
Jan 30, 2017 03:25 AM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
linedr89
Aug 17, 2015 05:11 PM
nervseele
Texas
Jul 29, 2015 08:49 PM
