tokico d spec adjustment? how do i know what setting it is on?
Old Jul 1, 2008 | 01:24 AM
kingrukus's Avatar
I just purchased a set of Tokico D Specs' and they didn't come with the adjuster key (I am going to just use an allen/hex key to adjust them). Anyhow, how do I know what setting the struts are on? There is no sticker indicating the actual number that the compression/rebound is set at. I will be using them with G35 coupe Tein S-tech springs.
Thanks
Old Jul 1, 2008 | 01:28 AM
kingrukus's Avatar
Okay, I just read from searching that turning them via allen key clockwise till it stops is full stiffness. Then turning them 7 turns will bring it back to full softness. Apparnently most guys here turn them 3.5 to 4 times for a setting in the middle.
Old Jul 1, 2008 | 03:46 PM
ResIpsa's Avatar
The trick with adjustable shock suspension tuning is to understand the basic concept that adjusting a shock softer will increase traction in that wheel.
Start out with all the shocks set at the same setting. Three turns from full firm is a good start. Now go for a drive on some twisty roads. How does it feel?
Assuming that you are not experiencing excessive over steer (your rear tires breaking loose before your fronts), turn your front shocks one additional 1/2 turn soft (now 3 1/2 turns from full firm). Now go for a drive. You should notice a big difference. Your steering will feel lighter and the car will be much more "flickable" around corners. However, depending on your tires, springs, etc. your car may feel too unstable.
Now, go back and adjust the fronts one full turn firm (2 1/2 turns from full firm). Your steering should feel much heavier and smoother.
The trick is finding that magic balance between the fronts and the rears. Once you know it, it does not matter if you run a kidney jolting 2 turns from full hard or comfortable 6 turns from full hard.
Old Jul 1, 2008 | 11:31 PM
BadBoy06's Avatar
I'm running mine 1.5 off firm with my sways in the middle.
handles like an evil woman lol
Old Jul 2, 2008 | 10:53 AM
ResIpsa's Avatar
That setting makes my girlfriend nauseous. I have to remember to adjust full soft (yes, full soft) before I pick her up.
Old Jul 2, 2008 | 01:05 PM
kingrukus's Avatar
You are a considerate person....regardless of who the person is, if they cannot ride in my car, they can walk.
Old Jul 2, 2008 | 01:24 PM
ResIpsa's Avatar
What can I say, I'm a considerate guy.
And you should always use only three dots, or ellipsis, when omitting a word, phrase, line, paragraph, or more from a quoted passage.
Old Jul 2, 2008 | 01:53 PM
kingrukus's Avatar
Old Jul 4, 2008 | 08:21 PM
OCG35's Avatar
a forum is not an essay... I use "..." all the time - it's like pause when verbally speaking.
Flame on grammar/writer teacher
Oh BTW - good pointers on adjusting shocks... I will be getting some soon (I hope I can find this thread when I need it)
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
linedr89
Aug 17, 2015 05:11 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
