Guys with BC coilovers - need help!!
Old Jul 10, 2008 | 01:16 PM
  #31
Black Guy's Avatar
Here is the difference gentlemen. Old design vs new design
Old Jul 10, 2008 | 01:21 PM
  #32
redlude97's Avatar
are the new springs progressive then?
Old Jul 10, 2008 | 02:23 PM
  #33
OCG35's Avatar
looks like old are linear and new are progressive... The problem is; most reviews I've read are from the old design... so I'm not sure what kind of reports are coming from new?...
Is the old design still available?
Old Jul 10, 2008 | 03:14 PM
  #34
Black Guy's Avatar
The springs are not progressive. The old design is no longer available.
Old Jul 10, 2008 | 04:26 PM
  #35
redlude97's Avatar
how are they not progressive when the springs are wound at what appears to be the same spacing while the coil diameter gets smaller
Old Jul 10, 2008 | 04:36 PM
  #36
Klubbheads's Avatar
coil diameter has nothing to do with the spring progressive or not. Pitch rate is more of an indicator if the spring is progressive or not. In the pics provided it looks like both of them have the same pitch rate from top to bottom so both of them are most likely linear.
Old Jul 10, 2008 | 04:40 PM
  #37
OCG35's Avatar
exactly - that's why I thought they "looked" progressive... also, there's this:
Originally Posted by Glex25
If you have the newer springs(:Progressive) that are kind of fat in the middle you don't need the lower bucket according to Pete@BcRacing.
No clunking sound here.
I adjust springs first and then adjust the shock body until it gets tight or vice versa.
Remember you don't want slack on your springs cause that means that you will be riding on more shock than spring and can blow out your shock body.
Old Jul 10, 2008 | 04:48 PM
  #38
redlude97's Avatar
of course it does. If the spacing between coils remains the same while the diameter decreases, guess what! the pitch rate changes!
Old Jul 10, 2008 | 04:57 PM
  #39
OCG35's Avatar
Wouldn’t the coil diameter make a diff - if the spacing is the same and the thickness is the same? the broader wound part will flex the same as the smaller diameter?
I'm clearly not a suspension expert... in fact the more knowledge I can gain here, the better position I'll be in to make the right decision.
Frankly, I'm not entirely swayed form keeping Eibacs and using D-specs
*Edit: I didnt read redludes post prior to mine... he says it a little clearer. (hard to carry biz converations and this at the same time )
Old Jul 10, 2008 | 05:08 PM
  #40
OCG35's Avatar
black guy... can you clear this up please... also, you never responded in the other thread as to whether these are still available: https://g35driver.com/forums/showthr...=204686&page=7
Old Jul 10, 2008 | 05:11 PM
  #41
Klubbheads's Avatar
Im not sure if a chose the correct word to explain but if the distance between each roll is the same and the force is vertical, which in our case it is, then spring is linear because it takes the same amount of force to compress the spring for each lets say inch. If the spring is denser in the bottom then that would automatically be progressive.
Old Jul 10, 2008 | 05:24 PM
  #42
redlude97's Avatar
I misused the term "pitch" in my explanation. By pitch I meant the angle the spring forms. I forget that its usually defined as the spacing.
Look up a conical spring, if the spacing(pitch) between the springs is the same while the diameter changes, then it has a nonlinear springrate. No linear spring requires the same amount of force to compress it each inch. A linear spring refers to a constant springrate, but the force changes proportionally to the compression, which is governed by hooke's law f=-kx, where in a linear spring k is constant, while in a progressive spring k=k(x). Now if the conical section of the spring in question is fully compressed with the weight of the car, then the rear spring behaves as a linear spring even though technically it doesn't have a linear construction
Conical helical spring can be designed in two ways
1. As a linear spring where the pitch is variable so that all coils will come to touch each other at the same time when pressed to solid.
2. As a non-linear spring where the pitch is constant. Therefore the largest coil will touch the coil above it first and then the second and so on thereby, creating a non-linear rate spring where each time a coil reaches the coil above it the number of active coils decrease and the rate of the spring increase.
The rate of the first type of spring can be calculated/estimated as a standard helical coil using the average diameter of the conical spring. The stresses should be calculated with respect to the largest diameter because the stresses are the highest at the largest coil.
Calculating the variable rate of the second type is more complicated and done in steps. First you treat the spring as a normal spring until the largest coil touches the coil above it. Then you deduct one coil and do the calculations until the next coil touches the coil above it and so on. Since the smallest coil will be the last to work, the stresses are calculated with respect to the smallest coil.
Old Jul 10, 2008 | 05:25 PM
  #43
05GRide's Avatar
If you look back at my post on the first page, Adam at z1 auto called BC Racing and they told him the new springs are NOT progressive. I had Adam ask that specific question to them. So while I agree that they LOOK progressive, the manufacturer is saying that they aren't.....
Old Jul 10, 2008 | 05:45 PM
  #44
Klubbheads's Avatar
It clearly states the there is an average rate for the whole spring compression process therefore making it a linear rate. If it was talking about the linear spring that u are referring to, there wouldn't be an average diameter because there would only be one throughout the length of the spring. Average diameter means that the top portion of the spring has different diameter compared to the bottom portion.
Every kg/lb force on a linear spring will have the same effect throughout the springs compression no matter how much it compresses.
Old Jul 10, 2008 | 05:50 PM
  #45
Klubbheads's Avatar
BTW i highlighted them so i would be clear which part of ur post i was responding to, so don't think im yelling. LOL
