Help verifing if my alignment is within specs.
Old Jul 14, 2008 | 04:01 PM
RST531's Avatar
I just took my car in this wekend to get aligned. To me everything looks fine but a friend said they look like it has to much camber. I have the alignment sheet attached if anyone can tell me if everything is fine. TIA
info: I'm dropped on Tein Flex, with SPL front camber and SPC rear camber.
Attached Thumbnails Help verifing if my alignment is within specs.-rst531-alignment.jpg
Old Jul 14, 2008 | 04:05 PM
redlude97's Avatar
Looks pretty good, but it also depends on what you are looking for in an alignment setup. Thats a pretty conservative setup that should provide even wear of the tires if you don't drive it hard. I personally would run more negative front camber which provides better handling, but I drive my car pretty hard alot of the time.
Old Jul 14, 2008 | 04:14 PM
RST531's Avatar
Great, I know you know your stuff redlude97, so I def sure its fine. I wanted a conservative setup that will give me good wear on the tires. Plus I dont drive hard often so its a good mix right between both, i hope. Thanks.
Old Aug 8, 2008 | 12:04 AM
jlin615's Avatar
Which shop did you go to? I'm planning to get front and rear camber kit, will they adjust it too?
Old Aug 8, 2008 | 11:32 AM
RST531's Avatar
I went to Temple City Auto in Temple City. And YA they will adjust the cambet kits, i have front and back camber kits and they did it with no problems. i would highly recommend them!
heres their website: http://www.templecityautorepair.com/
and a few reviews of them:
https://g35driver.com/forums/souther...good-shop.html
https://g35driver.com/forums/souther...pair-tire.html
Old Aug 8, 2008 | 06:01 PM
superchargedg's Avatar
Those specs are perfect for good tire wear.
Old Aug 8, 2008 | 06:19 PM
jlin615's Avatar
+1
Even more perfect if it doesnt cost over $800 for the camber kit/installation/alignment.
Old Aug 8, 2008 | 06:47 PM
RST531's Avatar
^^ idk about that, but front and rear camber kit cost was about $650 and the alignment was i think $80 or $100. I saved some cash by installing the camber kits myself.
superchargedg - thanks, its perfect for me for now. until i get some nicer rims.
Old Aug 10, 2008 | 03:41 PM
zt967's Avatar
-1 in the front is overkill. I drove for 10k miles with -2.1 camber in the front and noticed no abnormal wear in the front /w stock 19's /w Bridgestones, which is what I assume you have. Its the rear thats killer ._. Your spec should be fine back there.
Old Aug 14, 2008 | 01:18 AM
mpapers's Avatar
you must not have checked the front inside of your tires or are not at -2. Even with the stock -1 camber with 19s you get more innner wear and feathering. And when I went to -2 I shredded the inside of my tires in 4k miles. My friend runs -1.5 and his get shredded in about 10k but he likes it like that so.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
