suspension rattle, how to solve it?
Old Jul 28, 2008 | 08:13 PM
chrissportg35's Avatar
i recently install Stance coilover, Eibach swaybar, SPC rear camber. Now, the passenger side (F,R) start to create a small rattle when drive over a small bump, uneven surface. Any ideas what cause this rattle?
Old Jul 28, 2008 | 10:51 PM
CreativeDesignZ's Avatar
is it a rattle or a clunk? If its a rattle, your coil overs might not have the locking rings tight (the rings that push the spring up to the perch), if its more of a clunk it could be your sway bar endlinks on their way out, OEM's suck, look into power grids
Old Jul 29, 2008 | 04:13 AM
some time it sound like metal to metal and sometime it sound like rubber to metal (squeaking noise). i retight every suspension parts but the noise still there do you think because of a swaybar bracket that i over torgue. this audible noise is irritating my ears
Old Jul 29, 2008 | 08:44 AM
sounds like your sway bar might just need some lubrication, either that or compression rods
Old Jul 29, 2008 | 11:34 AM
Klubbheads's Avatar
lube the swaybar bushings and get new endlinks.
Old Jul 29, 2008 | 02:36 PM
kenchan's Avatar
your endlinks are probably loose.
Old Jul 29, 2008 | 07:08 PM
EL-EE-ES's Avatar
yeah check your end link...i lowered my car about 3 weeks ago, last week i got a rattle in the front pass. area on slow bumps. like coming off the driveway . took the wheels off on sunday to find that the end link was loose.
Old Jul 30, 2008 | 01:56 AM
i think because of the swaybar. i dropped my car down to 0 gap between the fender and wheel.....so i will check the endlinks plus greases the bushing. i will keep you all updated. Thanks for all your inputs and have a good one everyone!
Old Jul 30, 2008 | 01:58 AM
elayman's Avatar
is it possible to tighten the endlink through the wheel well?
Old Aug 8, 2008 | 12:48 AM
JC-RH's Avatar
any update on this??
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
