Relentless Autosports Strut Bar - (NOT VRT!)
Old Mar 20, 2009 | 01:18 AM
  #661
viceversa's Avatar
Originally Posted by DefJukie
I still have my brackets installed, just tightened them down with no crossbar to save time. Ive noticed my hood liner thing is cracked and broken but the hood clears my brackets fine, is the cross bar or brackets hitting for you?
didnt see this post earlier. I had to remove my hood liner in order for me to get the hood to shut all the way. to my surprise it doesn't look like the brackets are hitting but the bar itself is. right where the bar has that slight bend it in. let us know if you get it installed.
Old Mar 20, 2009 | 01:21 AM
  #662
lekker_droom's Avatar
Originally Posted by viceversa
better pic with the assistance of my little sister heh
<a href="http://picasaweb.google.com/lh/photo/4TN-V3Abui-SoSy4J898fQ?feat=embedwebsite"><img src="http://lh4.ggpht.com/_EDb1cJHu1bk/ScMOX6TpKzI/AAAAAAAAAIw/ME4RBvx2D4Q/s800/DSC_1124.JPG" /></a>
More pics of your sister?
Old Mar 20, 2009 | 01:32 AM
  #663
viceversa's Avatar
sure, shes all yours
Old Mar 20, 2009 | 01:34 AM
  #664
Not sure what I should say...
You should have a talk with her.
Old Mar 20, 2009 | 12:39 PM
  #665
psedog's Avatar
Back in SD**
Originally Posted by Beebo
^^^ damn i shoulda had mine chromed... looks sick
+1 That would have went well with my polished plenum (once I figure out how to re-polish it, damn international freight shipping)
Old Mar 21, 2009 | 11:28 AM
  #666
DefJukie's Avatar
Hey viceversa, so I tried installing it again, i loosened both brackets, put the cross bar in place and was able to get one screw all the way thorugh and the other halfway just like you. Before I even attempted the crescent wrench, I tried closing the hood and guess what, the EXACT same spot on my bar hits my hood and I cant close it. The bend on the cross bar on the passanger side about 1/4 of the way across hits and the passanger side hood has a gap like yours.
Any luck with a shop and anyone else have this issue??
Old Mar 21, 2009 | 11:43 AM
  #667
Cubanl81's Avatar
my question is why should everybody go thru all this trouble. If more then one is having this problem. Shouldn't it be a problem Scott should fix. For the money I paid for this I don't want to have to dish out more to get a shop to fix it.
Old Mar 21, 2009 | 11:58 AM
  #668
I'm just going to have a shop install mine.
I'll be getting Hotchkis sways put on and corner balancing at the same time. I'll let you all know how it goes, won't be until the first weekend in April though.
Old Mar 21, 2009 | 01:42 PM
  #669
lowrider's Avatar
Of course you're right. Just to add a little more information. As I indicated earlier, I was one of the first to get this bar, three years ago. After the first install, both supports hit the hood. I spoke to Scott about it, and he fabricated new supports, and I reinstalled them with the bar, and the fit was perfect. So, this is not a new issue. I assumed it had been solved. The bracket to hood tolerance is very tight. It appears, from what I've been reading, that perhaps a new left side support might be needed here.
BTW, when I installed mine, my car was on level ground, it was not on jack stands, so the wheels were not hanging.
Lou
Old Mar 21, 2009 | 07:28 PM
  #670
psedog's Avatar
Back in SD**
Is it only the coupe guys that are having this issue? Or is Tim the only sedan guy who has his?
Old Mar 22, 2009 | 01:35 AM
  #671
Canadian's Avatar
Canada, eh?
For the people with it not fitting on the passenger side, I think I may have found a solution. Install it the other way around,with the logo facing the inside of the car. Seems to fit much better, as I was having the same problem with the bar not lining up with it facing out.
Old Mar 24, 2009 | 07:58 PM
  #672
DefJukie's Avatar
Lou
Anyone else who got this bar attempted the install yet and have problems? It also seems to me that a new passenger side bracket needs to be made, hood doesn't close and liner hits bracket.
Anyone else notice that the driver side bracket lines up perfectly but the passenger one requires a little force to match up the hole for the a-arm bolt once the 2 on the top of the strut are on?
Old Mar 24, 2009 | 09:26 PM
  #673
viceversa's Avatar
Yes this is exactly the same case with my bar. I borrowed someone elses bracket to see if theirs was any different but it was the same. I took pics a couple days ago before i took the bar off and im going to send them to scott requesting that he send me a new passenger side bracket. I will also upload those pics here shortly.
I spoke with a member on the forums who bought this bar years ago and he also mentioned he had exactly the same problems when he got his bar and had to get a new bracket from scott. If the majority of people are having this same problem then I'll be one to say the problem is not with our cars...
Old Mar 24, 2009 | 09:37 PM
  #674
G35sedan03's Avatar
i got a sedan and having the same issues. I will try what canadian said, to turn it opposite way and see if that works.
Old Mar 24, 2009 | 09:54 PM
  #675
viceversa's Avatar
it will work that way im pretty sure, but this 500 dollar bar was not designed to work that way and it should have worked right the first time. you can tell im pretty angry about all of this.
