My front right brake has started to squeak, so I know it is time for new pads. I have had my G35 for two years and am yet to encounter this. Is it an easy process? I used to change my pads on my 94 Integra and was not bad. Any experiences you all could share would be great. Thanks!!
Texasscout
close
- Join DateFeb 2005
- LocationSouth Texas
iTrader Positive Feedback100
iTrader Feedback Score(11)
Liked:2,116 Times in 1,768 Posts
It's not hard at all.
IF the rotors are still smooth (so you don't have to get them machined) you can do it in less than 2 hrs.
Jack up car, put on stands (break the lugs first, leave them on just loose)
Remove the wheels.
Remove the two bolt that hold the calipers on.
Remove the outside pad.
Take your Disc brake collapsing tool (cheap at any auto parts store) and push the piston back into the caliper.
This tool:
Take off the other pad
Insert new pads
Replace in reverse order.
Wash, Rinse, Repeat on the other side.
You can get buy without the tool, but you will need a big "C" clamp to collapse the pistons.
Remember to "bed them in" properly when you are done.
Remove the wheels.
This tool:
Insert new pads
Texasscout
close
- Join DateFeb 2005
Now you didn't say WHAT kind of brake you have....
Infiniti or Brembo? Year? Coupe/Sedan?
You are really helpful and I appreciate it. Not Brembo (factory I guess) the car is an 04 coupe. I bought it used last year. Does that make it an Infiniti brand?
Jeff92se
Red Card Crew
close
- Join DateMay 2005
- Locationɐʍ 'ǝlʇʇɐǝs
iTrader Feedback Score(24)
Liked:585 Times in 498 Posts
This site is a pain in the royal butt to navigate but there IS a diy section.
https://g35driver.com/forums/brakes-suspension-diy-231/
Texasscout
close
- Join DateFeb 2005
As long as they are not gold colored and thy don't say brembo, you have OEM brakes. Actually the Brembo pads are even easier to change. There is a DYI on YouTube on it. It's not hard to do, If you have done a disc brake car before, you can do this one. Good luck and I'll be around if you need anything else.
