350z unrevised springs
Old Aug 19, 2008 | 02:21 PM
Tollboothwilley's Avatar
what is it on this unrevised suspension that made it bouncy...was it the springs or the struts??
Old Aug 19, 2008 | 04:34 PM
g35freak86's Avatar
it's the springs. Higher spring rate. If you are interested, I got a pair of 07 rear 350z springs that I never used for sale. THey are the revised spring PM me if you want them
Old Aug 19, 2008 | 05:05 PM
az1anbeethoven's Avatar
it was the struts that were bad
Old Aug 19, 2008 | 06:45 PM
Tunerz_Store's Avatar
It's not the springs, its the shocks. They weren't dampened properly.
Old Aug 19, 2008 | 08:57 PM
g35freak86's Avatar
really? always thought it was the springs. Guess it's the struts!
Old Aug 20, 2008 | 11:33 AM
powerbait's Avatar
From what I've read the revised rear springs actually have a higher spring rate than the unrevised. I can't recall exact numbers but it was like 370ish unrevised and 420ish revised. I got a full revised 06 Z suspension on my 05 sedan and love it, the stance is very even, which I attribute to the higher rates in the rear, since most recommend using G coupe rear springs for an even look. I was on the stock sport suspension and the Z actually made a noticable improvement, much more than I was expecting.
Old Aug 20, 2008 | 01:16 PM
nhbfighter's Avatar
Not to jack the thread, but what do you all recommend for my 05 non sport sedan? Revised all around? coupe front with revised rear? Only looking for about an 1" drop.
Old Aug 20, 2008 | 01:22 PM
i love the 350z setup all around...its the best setup if you are on a budget
but you def want to get the revised setup
mine is unrevised and its sorta bouncy
Old Aug 20, 2008 | 02:58 PM
ttrank's Avatar
Grocery getter
The problem is the un-balance between the spring rate and the struts. You can blame either one and be right.
Old Sep 3, 2008 | 04:53 PM
JY35's Avatar
what is the difference between unrevised and revised
how can i tell the difference if i was too see it (something with dots)
is it the year of the Z which determines the revised or unrevised label?
Old Oct 13, 2008 | 04:44 PM
68_GT's Avatar
do the un revised springs give the same drop as the revised springs on an 05 Sedan ?
would unrevised springs be OK on an 05 Sedan with sport suspension ?? looking for the same drop as the revised springs for a friends G Sedan but can't seem to find them and I just came across a set of unrevised springs.
any help ?????????
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
