LOWERING need some advice
Old Aug 27, 2008 | 04:40 PM
AllNatural's Avatar
I have an '04 coupe. I want to lower it about an inch all around. Need some advice on what lowering springs I should use and if I NEED a camber kit?
Thanks
Old Aug 27, 2008 | 04:45 PM
dofu's Avatar
20 Year Member
Anything under 1 1/2" should be fine without a camber kit, but many would suggest you get a camber kit all the way around. I would say you would need a toe kit for the rear at the most.
Old Aug 27, 2008 | 04:50 PM
AllNatural's Avatar
How would I find out for sure? from the dealer after I put the springs on or would I be able to notice from just driving?
Got any tips on any reputable brands?
Old Aug 27, 2008 | 04:58 PM
nghiars's Avatar
If all you want is about an inch drop you can look into getting used 350z springs/tein s-techs/tein h-techs. Shouldnt cost you too much and i would recommend rear camber/toe kits since the rear tires are usually more expesive. rear its go for about $150. the front kits however go for about 350 but if you can afford to get those, go for it. if you can afford coilovers, i would go that route too since you can adjust the height and sometimes damepening as well
Old Aug 27, 2008 | 05:29 PM
AllNatural's Avatar
I think the coilovers are a bit too expensive... lol I might be able to get some used tein springs... then just would need to dish out for the camber kit.
Thanks
Old Aug 27, 2008 | 06:01 PM
nghiars's Avatar
theres a guy here trying to trade/sell his g35 tein s techs.. it will give you a moderat edrop and i got my eibach(really made by spc) rear camber kit for 160 shipped from a vendor here...
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
B03Sedan
Sep 22, 2015 10:37 PM
Paragham
Sep 15, 2015 12:04 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
