Brembo Brakes
Old May 12, 2004 | 11:34 PM
Skyline_G35's Avatar
English dude, English
Brembo Brakes
Can you take the 350z or g35 coupe brembo brakes and put them on the 6mt sedan?
Old May 13, 2004 | 12:19 AM
al503's Avatar
Re: Brembo Brakes
yes. zimbo's taken $1.99's brembos and put them on his sedan. You'll have to trim off a plate or guard though, which is no big deal.
Old May 14, 2004 | 04:16 PM
Re: Brembo Brakes
$1.99? I don't understand.
Old May 14, 2004 | 04:35 PM
dollar99's Avatar
Re: Brembo Brakes
me
_________________________________
430+ Horsepower at the crank.
Old May 14, 2004 | 05:15 PM
zimbo's Avatar
Re: Brembo Brakes
Voila!
It ended up being a bigger pain than I had anticipated (since I ended up needing spacers in the rear which meant replacing all of the hub bolts), but the end result looks exceedingly cool IMO.
Also, until I get slotted rotors and braided brake lines this is more of a cosmetic mod than a performance mod. The Nismo LSD was a much better bang-for-buck in terms of performance (you listening, Jimmy? hehehe .
--Steve
Old May 15, 2004 | 02:26 PM
geeitup's Avatar
Re: Brembo Brakes
Very nice. If you increased the rotor diameter along with the beefier caliper then you got the performance. Increasing the swept area matters more than "slotting." Let us know if your upgrade helps rear brake wear.
Old May 17, 2004 | 01:35 PM
dklau33's Avatar
Re: Brembo Brakes
Putting on the Brembos or any other aftermarekt big brake upgrade kit on the Sedan will not yield greater performance for the typical street scenario. Where these brakes are needed are for track days where repeated hard braking is being done. The bigger rotors will be able to absorb more heat and be able to disipate it faster. The better brake pads will have higher operating temperature limits and will resist fade. The bigger and more amount of pistons in the calipers will have stronger clamping force that can be applied to a greater surface area over the brake pads. The stock brakes on a G35 already do a very good drop at braking on the street. Brembos aren't necessary for the street unless you do some crazy, repeated, heavy braking or you just want the Brembos for show.
04' G35S 6MT Ivory Pearl, Willow, Premium
Old Aug 28, 2005 | 03:00 PM
myG35ZX's Avatar
What offsets do you have? What is ideal?
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
