What Rear Camber Kit to get?
Old 09-15-2008, 05:01 PM
badnblk's Avatar
i dont really understand the toe bolt thing. im looking at buying the battleversion camber kit. does it come with toe bolts or should i get the spc toe bolts? plus wat do the bolts do?
Old 09-15-2008, 06:02 PM
jhurst's Avatar
Obviously toe bolts allow you to adjust the "toe" of your wheel/tire. The SPC/Eibach kit allows +/-3 deg. of adjustment, which is done simply by loosening and moving/spinning the toe bolt. Installation is simple, you just have to drill or burr out a little bit of metal to allow for +/-3 deg. adjustment.
P.S. Toe is very important, if the toe of your wheel is off you will know it immediately (i.e. the steering wheel will not be straight....I know from experience).
Old 09-15-2008, 06:04 PM
jhurst's Avatar
I would recommend the SPC 72050 kit (x2). I got my set from THmotorsports for like $155 (I think they've gone up though ), but it is by far the most popular and you will be able to get more help with that kit than any other out there.
Old 09-15-2008, 06:05 PM
badnblk's Avatar
can i just get the 72055 kit which is just the bolts and use them with the battleversion rear camber kit?
Old 09-15-2008, 06:06 PM
redlude97's Avatar
Originally Posted by idrive_MD
since it was mentioned why are the toe-arms a bad idea...i've noticed there are only a few out there, so enligthen me?
"toe" arms are a bad idea because they change 2 planes of suspension geometry as they are lengthened, which affects both toe and rear "caster", whereas the toe bolts in the OEM location only change toe as a result of their adjustment.
Old 09-15-2008, 06:08 PM
jhurst's Avatar
can i just get the 72055 kit which is just the bolts and use them with the battleversion rear links?
Yes, that would work too.
Old 09-15-2008, 06:09 PM
badnblk's Avatar
thanks for the help never understood how those toe bolts worked
Old 09-16-2008, 03:51 AM
Dranom's Avatar
an thoughts on this EIBACH kit? i got it at JSC for 135 shipped and im planning to get it installed w/ my fron SPL a arms
Is the toe adjuster any good? coz i also have a SPC toe bolt
http://www.jscspeed.com/350z/suspens...ach_camber.htm
socalg35x
08-07-2015 09:36 AM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
beevanhuynh
07-23-2015 01:37 AM
nascarbuff17
07-16-2015 10:23 AM
Quick Reply: What Rear Camber Kit to get?
