Replacement shocks?
Old Sep 24, 2008 | 09:50 PM
WhiteMikeG35's Avatar
Replacement shocks?
What kind of shocks/struts can I get to replace the OEM parts? I have 80k on the car and need to change them, what have people used that is comprable to OEM.
Old Sep 24, 2008 | 10:45 PM
athens's Avatar
What were the symptoms of the worn shocks??? Any irregular tire wear on the front tires?
Though Tokico makes the OEMs for Nissan, the closest aftermarket Tokico is the HP and it is supposed to be slightly harder in ride than OEM. Tire Rack advises KYB Excel-G is the way to go for OEM replacement. Of course you could just go OEM.
I thought mine needed replacement at 50K miles, but it turns out they are OK. Just that our roads here in Chicago were badly beaten up by the past winter. Can't understand why shocks shouldn't last to at least 100K car is driven hard.
Whatever you do avoid Koni reds. Used them to replace OEM on a Ford Taurus SHO several years ago, even with stock springs. SHO crashed on every expansion gap like a stage coach over a dry gulley. Even with adjustment to high compliance setting. Had to cut out the brand-new Konis. Went to the OEM Motorcrafts (made by Gabriel) and the civilized ride had returned.
Old Sep 25, 2008 | 02:33 PM
G-MENTED's Avatar
im a tokico fan
snic09
Nov 8, 2017 01:46 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
smartin0924
Aug 13, 2015 07:29 PM
si_driver
Aug 11, 2015 07:08 AM
cyrus32
Jul 18, 2015 06:22 PM
