Can you mix/match Rotors / calipers?
Old Oct 24, 2008 | 02:38 PM
SIN3's Avatar
stupid question but I was just wondering if you can do this. I have the rotora bbk 6/4 pot set up. My rotors are getting pretty bad and wanted different rotors. buying just the rotors are a big costly and wanted something else. any suggestions. No one can give me the right answer. thanks
Steven
Old Oct 24, 2008 | 02:59 PM
Canadian's Avatar
Canada, eh?
If you can get the exact same size rotor, I don't see why not?
Old Oct 24, 2008 | 04:34 PM
SIN3's Avatar
thats what I am thinking. 355mm is the size front and rears but has anyone done this and any good alternatives to rotora?
Old Oct 24, 2008 | 05:40 PM
redlude97's Avatar
you have to make sure the hat offsets are the same also.
Old Oct 24, 2008 | 05:48 PM
Jeff92se's Avatar
Red Card Crew
Exactly. If the above is common, you might be able to find some other bbk maker offering compatible rotors but I doubt they would be much cheaper. 2 pc rotors are pricey but alot lighter than the same sized 1pc units. But you don't have to replace everything, use the same hat and just replace the rotor portion. From what I read, yes they are expensive but also last much longer(reducing their cost)
If you want to run cheaper 1 pc rotors, good luck finding them. And even if you could find 13" or 14" 1 pc rotors, they will weight a friggin' ton.
Old Oct 24, 2008 | 06:18 PM
Triple8Sol's Avatar
You silly girl. Z/G owners get pretty/flashy gigantic aftermarket bbk's for looks, not performance. Who cares about physics like mass and stopping distances and heat dissipation and performance? Thought you knew.
Old Oct 24, 2008 | 07:04 PM
SIN3's Avatar
exactly...... all a bunch of show off ****** with your 20s and bbk... oh wait... thats me..
Old Oct 24, 2008 | 07:17 PM
SIN3's Avatar
just got off the phone with my peeps at rotora, yes you can but the offset has to be right most bbk for the G35 are standard with 355 size and can be swapped out. i cannot just buy the rotor and keep my hats because i have the first Generation of the bbk (3 years old) they made a V2 and the hats are different and colored now. joy
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
