BC coilover (rear not low enough?)
Old Jan 5, 2009 | 03:25 PM
SilentAttack's Avatar
Ok so I bought and installed my BC coilovers. The front could be adjusted where the car could pretty much sit on the ground. The rear is a different story. I have spun the spring as low as it would go and have done the same with the shock. Now I notice it is about maybe.. 1 inch lower than stock. Is there a reason the rear can not go any lower? I figured putting coilovers on would give me about a 3 inch range for lowering.
Old Jan 5, 2009 | 03:57 PM
GLuXuRy's Avatar
depends on coilovers .. my Stance coilovers can sit lower than Tein's will
some people max out their Teins and still wont come close to what the Stance coils can do
Old Jan 5, 2009 | 04:25 PM
GreenGoblin's Avatar
The goblin resurrection
cut the spring mount and ditch the locking ring
Old Jan 5, 2009 | 04:27 PM
redlude97's Avatar
I thought the BC coilovers don't use the stock springmount? +1 on removing the locking ring though, I would ditch both rings
Old Jan 5, 2009 | 06:16 PM
Klubbheads's Avatar
something does not seem right. My BC coilovers were rears were almost 2 inchs lower and it had more room to go.
Old Jan 6, 2009 | 11:10 AM
Maybe I will remove the adjustable part in the back, that woudl give me about another inch. Once I put wheels on I may put them back on. Either way I just figured it would give me about 3 inches max to work with. The rubber mount on the top must stay in right? I figured it was important because that is the weight of the car pushing down on the spring.
Thanks for the suggestions.
Old Jan 6, 2009 | 11:33 AM
I thought that they did, I dont have them so I could be wrong.
Old Jan 11, 2009 | 05:49 PM
SFLG35's Avatar
FGC President
there is not spring mount in the rear, it is removed.
you can only remove the top lock ring as the bottom (larger) one seats the spring so it doesnt move around.
what spring rate setup did you get? higher spring rates will drop the car less, due to them being able to support more weight of the car before compressing.
if you are still want to go lower after removing the top lock ring, let me know. we can see about getting you some 180mm springs instead of 200mm spring. these are the ones i run on mine and you can put the rear on the floor if you want.
Muski_G
Dec 1, 2023 11:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
