Need rotor help asap - About to purchase
Hey Guys... need some help in a hurry... simple question for you guys:
I drive a 05-G35 6MT (non brembo -
I need new front rotors and pads... will these work without any additional mounting hardware etc?
Pads:
http://www.horsepowerfreaks.com/part...va_Street/7964
Rotors:
http://www.horsepowerfreaks.com/part...d_Slotted/8891
(i know thats only one of em
) but I need to get new ones asap... and Just want to make sure I will not need any additional mounting stuff. Thanks a million guys - in advance
)I need new front rotors and pads... will these work without any additional mounting hardware etc?
Pads:
Rotors:
dealerships charge alot bro ..if you can find a local reputable shop to do it . i suggest you go there .. itl be cheaper also ..
plus do you know you have to break your new parts in as soon as you put them on .??
try Midnight Performance In Rancho Cordova. Right off Sunrise.
Google they're contact info.
Pad and Rotor Bed-In
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
why slotted and drilled.
You reducing your braking surface dramatically.
It would almost make sense if you were going with BBK (Big Brake Kit) and getting slotted and drilled rotors. Therefore increasing braking surface by getting bigger rotor and at the same time decreasing it by getting slotted and drilled rotors, at the end prolly ending up with something similar to a OEM rotor.
But getting OEM size rotor that is slotted and drilled is just nonsense.
