Springs vs Coils
Old Feb 5, 2009 | 08:00 PM
Heinz's Avatar
Springs vs Coils
I have read that if i go for springs, i also have to buy camber kit, but what if i go for coilovers, do i need to buy the camberkit
Old Feb 5, 2009 | 08:11 PM
dofu's Avatar
20 Year Member
if you lower your car, you'll need a camber and toe adjustment kit
Old Feb 5, 2009 | 08:41 PM
repin_LB's Avatar
either way get a camber to save the tires. in the long run it will be worth it
Old Feb 10, 2009 | 05:02 PM
1992_eg's Avatar
listen to this guy
Old Feb 10, 2009 | 05:47 PM
dofu's Avatar
20 Year Member
Technically, excessive camber does not eat away your tires like excessive toe does. All camber does is give you uneven tire wear.
Old Feb 12, 2009 | 05:06 AM
kaspa666's Avatar
do u need to get cambers on front and back with the coilovers?
Old Feb 12, 2009 | 09:18 PM
baseball23's Avatar
yes i would like to know more about this also. My front tires are about 5 months old and the inner part of the tires are gone!! what do i need? camber kit and whats a toe adjustment?
Old Feb 15, 2009 | 07:27 PM
Heinz's Avatar
What is recomended for the rear?
Both camber arms and camber toe bolts, or just the Camber arms, or just the camber toe bolts???
Camber arms:
http://cgi.ebay.com/ebaymotors/FAIRL...Q5fAccessories
Camber bolts:
http://cgi.ebay.com/ebaymotors/SPC-R...Q5fAccessories
Old Feb 15, 2009 | 07:32 PM
dofu's Avatar
20 Year Member
Originally Posted by Heinz
When is recomendedfor the rear?
Camber arms:
Camber bolts:
Camber and toe are two completely different things and are adjusted differently. There is no single bolt to turn to adjust both at the same time. With that said, rear camber is usually adjusted with an arm like the one you posted, while toe is adjusted by a bolt like the one you posted.
You will need both the toe and camber kits for the rears... and although the front toe is already adjustable from the factory, you would want still want both camber and toe adjustment kits for the front. If you've only dropped the front by an inch and a half or less, I wouldn't say the front kits are required (just better to have).
And quite honestly, I would not trust that camber adjustment bar in that ebay link...
Old Feb 17, 2009 | 10:14 PM
repin_LB's Avatar
oooo yea i forgot to mention get the complete rear camber kit, arm and toe bolts my bad. yea toe wear the tires the most
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
