Squeeks?
Old Feb 10, 2009 | 02:10 PM
Wannabe6MT's Avatar
-MN G Crew-
Squeeks?
What would cause my brakes to squeek when im just rolling forward slowly (with brakes being applied) It is very loud.
Old Feb 10, 2009 | 05:27 PM
keff108's Avatar
I actually have the same problem I get very embarrassed when it happens too.
Old Feb 10, 2009 | 05:28 PM
jwolfpk's Avatar
Me to i hope i dont need brakess those Brembos are pricey...
Old Feb 10, 2009 | 05:49 PM
kennejp's Avatar
I have the same problem and just got brand new brakes and rotors 2 weeks ago its so annoying and embarrassing- anyone know how to fix this?
Old Feb 10, 2009 | 07:19 PM
Wannabe6MT's Avatar
-MN G Crew-
I thought it might be the pads or somthing.
Old Feb 10, 2009 | 07:32 PM
Dxplicitone's Avatar
My first guess would be the indicators on the pads, telling you its time for new pads. Many pad manufactures have a small metal tab on the brake pads that when the pads wears down to it the metal tab makes contact with the rotors and gives you a squeal sounds. My girls IS300 was just doing this in the rear. First thing i would check would be your brake pads to see if your worn to that level.
As for the person above who says they just had their pads changed, in some cases your rotors might have been greasy or dirty after i fresh changed and that may cuase it but not after 2 weeks, by this time i imagine that would have worn off with regular daily use. I might take your back to the shop that did it, or if you did it yourself might want to go back and inspect.
Old Feb 10, 2009 | 09:07 PM
kennejp's Avatar
Ya I know I would take it back to them- but I just went back to school which is 5 hours away so cant just swing by- its just really frustrating!
Old Feb 11, 2009 | 09:29 AM
Beebo's Avatar
brake job lol
Old Feb 11, 2009 | 12:48 PM
Wannabe6MT's Avatar
-MN G Crew-
You think? Bah, somthing else to do this spring. Maybe i'll buy some cross drilled rotors.
Old Feb 11, 2009 | 02:15 PM
yourdoinitwrong's Avatar
I had that same problem with my front pads and it turned out to be dirt. On the pads I have there is a small vertical space in the middle of the pad (makes it look there are actually 2 smaller pads) and some dirt built up in this space. After the dirt was cleaned out the noise went away. I know that's not a very technical description but that's the best I can describe it considering my lack of mechanical knowledge!
cloudkid
Sep 10, 2004 12:25 PM
Rudeboy
Mar 9, 2004 12:48 PM
caliguy1973
Jan 23, 2004 09:45 AM
GraphiteG35
May 4, 2003 05:08 PM
