Compression rodzzzzzzzzzzzzz
Old 04-01-2009, 11:49 PM
AARONHL's Avatar
I noticed creaking from the front of the car going slow over cracks/bumps the other night when it was really quiet outside.
I'm in the process of finding the most inexpensive RODS.
Old 04-06-2009, 08:41 PM
monster520's Avatar
just get the revised bushing. dealer charges 300 for parts and labor.
Old 04-08-2009, 07:08 PM
05GRide's Avatar
Do you have a part number for this "revised" bushing? Where does the bushing go? It's not the bushing between the upper control arm and the knuckle right? This is the bushing on the compression rod itself?
As long as you don't need a gear puller or anything, I'd hate to pay that much for them to replace the bushing!
Old 04-08-2009, 09:11 PM
AARONHL's Avatar
You need a special press to install the bushing. It is not something you will be able to do and most shops will probably not do it (besides the dealer). Anyway, there are two ends to the compression rod. I'm not going to replace just one bushing because the other end might be shot as well. I would rather replace the whole rod.
You can find the installation of the bushing in a TSB .PDF...
Old 04-08-2009, 09:42 PM
05GRide's Avatar
If I have an extended warranty does the dealership cover it? Does the fact that I have aftermarket suspension parts void that?
Old 04-10-2009, 01:04 PM
AARONHL's Avatar
They should cover it, just bring it into service to find out.
Old 04-10-2009, 03:06 PM
escobar929's Avatar
you should be covered but there is always a deductable w/ the extended warranty
i have the same problem though, i really hate that creaking sound
Old 04-10-2009, 07:49 PM
DDD*G35's Avatar
I thought you only had to replace the Compression Rod Bushings to solve the problem. Now you also have to replace the Compression Rod as well.
Old 04-10-2009, 09:45 PM
godmans's Avatar
Originally Posted by G35 Mass
Feels like your tires are inflated to 50psi, right? Hard ride, front wheels bouncing off bumps?
Check your bushings of the Lower Control Arm (also known as Tranverse link), I had this problem and it felt like my front end was "skipping" during high speed cornering:
My bushing was totally torn apart and the arm was no longer centered
http://my350z.com/forum/brakes-and-s...g-failure.html
Old 04-11-2009, 04:40 PM
monster520's Avatar
compression rod bushing part#54570-ac70a you need two i paid a little less then 50 bucks. im out of warrenty so wasnt covered. my lower control arms look like the picture above. ordered a nismo bushing from mynismo.com for the control arm(transverse link).the only replacement bushing you can get for the lower control arms.
Old 04-12-2009, 11:32 AM
JLsG35's Avatar
I just had both mine replaced and feels like new and no more thumping noise. For those in four season climates, beware that the right side have a higer tendency of the bushings seizing - what a pain in the *** removing that SH*t!
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
sales@czp
Suspension-Vendor
26
11-06-2017 03:04 PM
prinny
11-22-2015 11:07 PM
The Fixer
Steering & Suspension
11-01-2015 03:26 PM
yosip1115
16
09-28-2015 04:14 PM
Quick Reply: Compression rodzzzzzzzzzzzzz
