Do i need a front camber kit, dropped on tanabe NF210
Old Mar 15, 2009 | 04:40 AM
4drmadness's Avatar
Hey guys, jus dropped my 04 sedan on tanabe nf210. the drop is about 2.2 inches all around. do u guys think i shud get the front camber arms?. I am already getting the rear camber kit, but dunno if i really need the front camber kit as well. any help wud be appreciated.
This is what the drop looks like.
Attached Thumbnails Do i need a front camber kit, dropped on tanabe NF210-g.jpeg
Old Mar 15, 2009 | 09:04 AM
EL-EE-ES's Avatar
2.2 inches...more than likely a front is needed
Old Mar 15, 2009 | 12:00 PM
4drmadness's Avatar
aite cool, thanks
Old Mar 17, 2009 | 04:04 PM
ttrank's Avatar
Grocery getter
A camber kit is never needed but a good idea to get your camber back into (or close to) OEM specs. If not, you will have more tire wear on the inside and require rotation more often.
Old Mar 17, 2009 | 04:06 PM
4drmadness's Avatar
I usually see people only getting the rear camber kit, i know that the fronts are much more expensive, but are the frontscloser to oem specs than the rears?
Old Mar 17, 2009 | 04:09 PM
ttrank's Avatar
Grocery getter
At that drop, no. It's more because the rear kits are less than half the price of the front.
Old Mar 17, 2009 | 04:40 PM
4drmadness's Avatar
so what do u suggest, shud i jus got both front and rear?
Old Mar 17, 2009 | 05:06 PM
1trueG's Avatar
Fronts arent needed as badly as the rears are, but they are always good to have. I am running no front camber kit and my front tires had camber wear on them. However, your front tires wont wear out that much faster without one.
Old Mar 17, 2009 | 05:14 PM
Klubbheads's Avatar
without camber kit ur front camber is most likely going to be a -2.0 and the rear close to -3. Your toe will most likely be within specs. For me personally i rather switch the tires from side to side every six months and have exceptional grip then go in to -0.8 camber and lose all that grip with a camber kit eventhough -3 camber is close to an overkill for a street car.
Old Mar 17, 2009 | 06:00 PM
4drmadness's Avatar
yea i think ill jus get the rears then and rotate my tires frequently
Old Mar 20, 2009 | 11:18 AM
LightsOut's Avatar
SIETESG
there is a commerical shop near my home that offers free lifetime rotation and mounting/dismounting after you pay $35 dollars to have each tire mounted. well worth it i think. i was gonna do that to my car since my front was out of spec, but i just didnt want to keep checking and worry about my tires so i purchased ichibia front camber for 285 shipped and 40 for install.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
