Anyone using this rear camber kit?
Old Mar 19, 2009 | 05:23 PM
G2007's Avatar
http://www.g35parts.com/9083/osc/pro...roducts_id=525
Just wondering if anyone had opinions on quality of these and how they compare with other camber kits. They run for half the price of most other rear kits...
Old Mar 19, 2009 | 06:26 PM
redlude97's Avatar
they don't come with any toe adjustments and are the same price as the ichiba/eibach kits.
Old Mar 19, 2009 | 07:31 PM
nghiars's Avatar
+1
I got my rear eibach (made by spc) camber kit with toe bolts from AJUSA(vendor here) for about 150 shipped.
Old Mar 19, 2009 | 08:13 PM
volcom_koda's Avatar
If your gonna pick these up, get the hole kit from EverythingG35. I bought the hole kit, and didnt need the toe bolts. If you plan to go low, you will need toe arms anyhow. If you are doing S-techs, or H-techs, without a springmount mod you should be fine.
Old Mar 20, 2009 | 10:20 AM
G2007's Avatar
I am not sure how low I'm gonna drop my G, but I'm planning to get BC Racing coilovers... I don't think I want to go too low, but when you say "the whole kit", do you mean I need both the camber arm plus the adjustable toe set? I just want to reduce camber/tire wear. Do I necessarily need both? Can I get away with one or the other?
Old Mar 20, 2009 | 10:33 AM
EL-EE-ES's Avatar
whole set= arms and toe bolts
toe will eat up your tires faster than camber.
id say get both and just install the camber kit 1st and see how bad your toe is. if the toe bolts arent needed you can sell them easy on here
Old Mar 20, 2009 | 08:38 PM
By the whole kit, I mean, get the front cusco arms that they offer with these rear arms for about 500 bucks. You can find toe bolts on here in the marketplace. I went with 350Z s-techs on my G with the front and rear kit and my specs are within factory by a mile. Without a toe bolts. But your getting coil overs, so i would by toe arms, not toe bolts.
Old Mar 20, 2009 | 08:42 PM
PTownG's Avatar
I went with ichiba. Identical to the spc arms except they are red and also come with toe bolts. really good price too
Old Mar 20, 2009 | 10:54 PM
G2007's Avatar
Thanks! Where can I find the Ichiba kit other than EBAY? I didn't see them on g35parts.com...
Old Mar 20, 2009 | 11:19 PM
PTownG's Avatar
right on this board:
https://g35driver.com/forums/suspens...-frt-rear.html
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
