Dealership Trying to Rip me off? Brake Problem (rotors)
Old Mar 22, 2009 | 04:57 PM
John6mt's Avatar
I went to the dealership on Friday because I heard a noise from my rear drivers side wheel which sounded like something was rubbing against my rotor as a drove at slow speeds. I went there and they checked it out and found that my passenger side rotor was cracked from overheating and said that someone drove with the E brake on which caused this therefore they cannot cover it under warranty. I told her I am the only one who drives the car and this cannot be possible, she ignored it and quoted me $550 to replace the 2 rear rotors this includes the $75 "inspection" fee since it wasnt a warranty issue. My car is a 2007 G coupe with 12k miles. Also the cracked rotor is on the opposite side of the wheel where the noise is coming from, so I dont even know if it will fix the damn problem. What should I do?
Old Mar 22, 2009 | 05:24 PM
Beebo's Avatar
That’s impossible since the e-brake is separate drum brakes, just LOL at them and walk away
Find a trusting shop to do the work
my dealership just told me that my rear brake pads were out and the rotor needed to be re-surfaced i asked what about the front and he said the front was fine, then i said fronts always go out befor the rear and he gave me some bs about how its a rwd car... i just LOL and walked away
he wanted 450 for just the rear I had my auto shop class do front and rear for 200
Old Mar 23, 2009 | 01:49 PM
Jeff92se's Avatar
Red Card Crew
Well technically it might be possible to heat the rotor up pretty good if the ebrake was left on. It might depend on WHERE on the rotor all the heat marks were. If it was on the rotor surface, then it points to a stuck caliper piston. Which would make it a warranty thing.
IF the ebrake was actually driven on, an inspection of the ebrake pads would be in order. Also the inside of the brake rotor would be very heat marked and I suspect the pads would be all worn out.
I encourage yourself to become knowledgable about the inner workings of your car to prevent dealers from turning warranty claims into the more profitable customer paid repair work.
Old Mar 25, 2009 | 12:20 AM
haagen_dazs's Avatar
i might as well learn something as well
are the ebrake pads different /separate from the normal brake pads?
Old Mar 25, 2009 | 12:23 AM
Beebo's Avatar
yup the e-brakes are small drum brakes
Old Mar 27, 2009 | 10:40 PM
alic4nte's Avatar
Get a mech that you can trust. I had my mech do my rotors/breaks, and all I had to do was buy him (and his crew) lunch. The stealership charged me $250 for each.
Old Mar 31, 2009 | 03:23 AM
John6mt's Avatar
I told em about everything you guys said and they ended up doing it under warranty thanks guys!
Old Mar 31, 2009 | 12:29 PM
Beebo's Avatar
sweet
ara777
Aug 15, 2018 04:11 AM
miata007
Aug 17, 2015 04:36 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
