Brake failure with Brembos?
Old Mar 30, 2009 | 06:56 PM
jrdemers's Avatar
Brakes Brake failure with Brembos?
I was curious if anyone on this list has ever overheated their Brembo's to the point of boiling the brake fluid (i.e. pedal goes to the floor.)
Old Mar 30, 2009 | 06:58 PM
redlude97's Avatar
people have brake fade on the track with the OEM brembos all the time. They are not that great on the track
Old Mar 30, 2009 | 07:20 PM
uf20wop's Avatar
i would think brake fade would be caused by the pad choice and fluid more so than the calipers
Old Mar 30, 2009 | 07:22 PM
jrdemers's Avatar
I would be interested in knowing if it is pad vaporization or fluid boiling? With pad vaporization the pedal gets hard and the brakes quit slowing the car. With fluid vaporization (boiling) the pedal gets "squishy" or just goes to the floor.
Old Apr 1, 2009 | 10:46 PM
Matthew121's Avatar
it would be...
Old Apr 2, 2009 | 01:01 PM
jrdemers's Avatar
Originally Posted by Matthew121
it would be...
Brake fade IS more about pad choice and rotor size, and when I was asking about the Brembos what I was really referring to was the high performance brake system overall - not the calipers in particular.
However, when you start pushing the limits of the brake system the thermal capacity of the caliper will start to play a part in preventing the brake fluid from boiling. Cast iron has a greater thermal capacity than aluminum and will therefore hold the heat instead of transferring it to the environment.
I just wanted to know how many people have experienced brake fade with the Brembos. Or for that matter, who has experienced brake fade with the standard brake system and high performance pads and rotors.
Joe
Old Apr 2, 2009 | 01:40 PM
Hi-TechG35's Avatar
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/BdJXtoBugpM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BdJXtoBugpM&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Apr 4, 2009 | 06:34 AM
Benny's Avatar
At the track I saw a driver with a STI and Brembo brakes, he drove very hard to a point the front caliper was discolored by the heat and lost brakes completely. He came to a stop on the runoff area, so no damage to him or the car.
Old Apr 4, 2009 | 05:46 PM
Buzz Killington's Avatar
From: Intergalactic proton powered electrical tentacled advertising droids!!!
I once drove a 04 coupe with brembos on a track day, it took a few laps, but eventually the pedal started getting squishy, and finally the brakes mushed out... I'd say it was a combination of pad fade and boiled fluid... When we finished our session the front and rear brakes were all smoking and the calipers were getting discolored.
Old Apr 4, 2009 | 10:30 PM
jrdemers's Avatar
Hmmm, if this is common then maybe the Brembos do need fade stop brake coolers.
Old Apr 6, 2009 | 06:49 AM
Nah, mainly better track oriented high temp pads and high temp brake fluid...
Old Apr 7, 2009 | 09:54 PM
jrdemers's Avatar
The high temperature pads are usually what leads to the vaporizing fluid since the fluid has a boiling point that is typically half that of the pad. A $50 dollar accessory that gets heat out of the caliper would significantly decrease that problem. Read through the flash movie I have at http://www.fourproducts.com/FSBC_Flash.htm
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
