Clicking noise from the rear because the car is too low!?
Old Apr 16, 2009 | 05:39 PM
biggz786786's Avatar
hey all, i have really bad rear clicking noise coming from the rear, happens when in reverse only
well, i have it in the shop right now, turns out that the car is too low, cause stress to the rear axle shaft
i will know within the hour if the entire shaft needs replace or just the boot or something
but is there any way to prevent this from happening without raising the car?
or how high should i raise it back up?
im lowered on greddy type-s coilovers
thanks
Old Apr 16, 2009 | 10:58 PM
05GRide's Avatar
I had a problem with a clicking noise from the rear axels some time back when reversing the car. Turns out this is a somewhat common problem. Took it to the dealership and they said they had to remove the axels and put them back in. Haven't had a problem since and was covered under warranty...
Old Apr 17, 2009 | 12:40 AM
they already did that, still happens
Old Apr 17, 2009 | 06:56 PM
bump!
turns out it's not cause the car is too low!
it has SOMETHING to do with the control arms, bushings, dampers, but don't know what!
the shop is STUMPED!
Old Apr 17, 2009 | 07:10 PM
eurodre's Avatar
yah dude, you won't get that problem because you are too low check out "clicking axle" im sure that search term will give you a lot of information
Old Apr 17, 2009 | 07:20 PM
^its not the clicking axle tsb, mine is an 06 5at coupe, and infiniti already checked for the rear axle clicking noise
Old Apr 17, 2009 | 07:25 PM
WILLIE BEANS's Avatar
Bump and good luck finding an answer ..
Old Apr 17, 2009 | 09:20 PM
eurodre's Avatar
oh i know what. its the greddy coilovers.. didnt know they MADE coilovers
Old Apr 17, 2009 | 10:37 PM
^haha of course they made coilovers, fyi, the greddy type-s coilovers are the most comfortable coilovers i have ever had
actually i just got it back from the shop
turns out the rear axle shaft needed lubrication, the control arm needed lubrication, the bushing needed lubrication, i also had squeaking from my rear cause my spl pro rear camber arms needed lubrication
also, if you have seen my recent pics, my rear suspension was a little lower than my front, giving it an odd stance, they raised my rear about an inch so now my rear sits 1/4-1/2 of an inch higher than my front, giving it a prowling stance
NO MORE SQUEAKING OR CLICKING YAY!
Old Apr 17, 2009 | 10:38 PM
eurodre's Avatar
oh really? oh interesting, you should try out other coilovers there are ones that are more comfortable out there for sure, sorry maybe it's just me but I wouldn't go with that kind of brand of coilovers. It doesn't seem greddy would specialize in suspension parts
but good you got your stuff to work now
told you its the rear axle.. haha
Old Apr 17, 2009 | 10:47 PM
haha, yes you did, and thanks for your help
believe me on the comfort thing
i have had H&R, tien basics, tien comfort sport, and a friend of mine has the hks hypermax3, when it comes down to strictly street driving and comfortability, i went with greddy
even tho they are going down hill HAHA
Old Apr 17, 2009 | 11:00 PM
eurodre's Avatar
what about JIC's and Function and Forms2?
Old Apr 18, 2009 | 03:19 AM
well i have herd good things from them, im not a coilover fanatic....yet!
but i went for the best bang for the buck
only cost me 1800 canadian including install thanks to a hook up! and couldn't be more happier
TWASkyliner
Feb 8, 2020 08:00 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Joshua615
Aug 31, 2015 12:29 AM
papo020
Jul 17, 2015 10:30 PM
