G35 Brembo question.
Old Apr 23, 2009 | 03:13 AM
polarxd's Avatar
I searched but couldn't find anything.
Are brembo brakes only on the 03 and 04 model 6mt's or are they on the 05's as well.
Old Apr 23, 2009 | 04:20 AM
VictoriousG's Avatar
^+1
Old Apr 23, 2009 | 04:44 AM
polarxd's Avatar
Huh?
Old Apr 23, 2009 | 05:04 AM
Gsouske35's Avatar
Yes they are only on the 6MT 03 and 04 coupes. 05+ use regular infiniti calipers.
Old Apr 23, 2009 | 05:23 AM
polarxd's Avatar
okay awesome!
Old Apr 23, 2009 | 06:30 AM
tomykas's Avatar
so witch brakes ar better? brembo 03-04 or regular 05-07 ?
Old Apr 23, 2009 | 06:36 AM
infg35coupe's Avatar
i was gonna ask the same thing.
Old Apr 23, 2009 | 10:34 AM
stingray1211's Avatar
if i am not wrong both models 60-0mph distance is roughly 110+ ft.
so the performance is similar.
Old Apr 23, 2009 | 10:49 AM
uf20wop's Avatar
but the brembos look so sexy
Old Apr 23, 2009 | 10:55 AM
Deezflip's Avatar
People say brembos are better for track use where constant braking is applied. More resistant to heat,fade, warping, etc.
IMO, It just depends on the quality of the pads itself, but i'm assuming that they're referring to the hardware itself about being durable in track situations...I'm not 100% sure.
Old Apr 23, 2009 | 10:59 AM
O HELLA OEM's Avatar
brembos look cool
Old Apr 23, 2009 | 11:01 AM
idrive_MD's Avatar
Like Deez said, the Brembo stock for stock will resist fade much better than the basic style calipers. They also have higher clamping force and increased pad surface contact if I recall correctly.
You can upgrade the basic OE system with better lines, pads, rotors and fluid and get a much improved setup that will more than likely survive a day of auto-x and roadcourse events, but if you want that added performance with the look to go with it, then there's nothin better than a brembo-type setup.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
