Need help with brake repair
Old May 6, 2009 | 05:01 AM
mchlgreen's Avatar
I wanted to know if there is anything that I need to know before I change my brakes and rotors ( 2007 G35 non Brembo). I'm not exactly mechanically inclined but I’ve changed brakes and rotors before. Is it pretty much like most other cars? I'm going to change the brake pads all the way around and the back rotors. Also any suggestions on cheaply priced rotors and/or pads that are good quality?
Old May 6, 2009 | 08:41 AM
pwebb's Avatar
front: 22mm for bracket, 14mm for slides
rear: 19 for bracket, 14mm for slides
you will need large channel lock pliers or a c clamp (use old pad in between) to compress the caliper pistons.
if you are reusing the hardware, clean it up nice with a wire brush (like you would use on a grill)
brake cleaner (brakleen) is your friend
use petroleum-free grease for the slides (rubber-safe)
if shims arent bonded to pads, put grease between them and pad.
Old May 6, 2009 | 11:02 AM
uf20wop's Avatar
project mu ns pads
centric premium blank rotors
PM Paul@USAutotek
Old May 6, 2009 | 11:06 AM
twin001's Avatar
Search in the Brake DIY section and subforum. Also, check out this page:
http://www.350z-tech.com/zwiki/350Z-TECH
Old May 6, 2009 | 12:54 PM
gary c's Avatar
All the above advice is excellent. I try to buy merchandise from our sponsors on MARKETPLACE or my favorite place for parts is Riverside Infiniti. Tony gives the Driver members great discounts on parts 1-800-919-8130....check him out. I believe he carries Hawk HP pads too, not sure about project Mu pads. Which ever you buy make sure you do the bed/break in process so you won't have issues with brake noise....Search under pad break in....
Gary
Old May 6, 2009 | 01:04 PM
Jeff92se's Avatar
Red Card Crew
Just buy the oem pads. Not much dust but retains the world class stopping power. Not sure why anyone would consider a non-oem pad with this setup.
You sure you actually need new rotors vs needing them turned?
Old May 6, 2009 | 01:06 PM
echang0501's Avatar
ebay has this seller from circle infiniti in NJ. east long branch maybe. He has pads for like 75 bucks. and i think oem seems to be the best for me. The rotors. Any where.
Old May 6, 2009 | 02:21 PM
uf20wop's Avatar
my brembo pads made a TON of dust
my wheels were black in a week
with the pmu NS pads the stopping force is the same and there is no dust at all
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
