New brakes and New Problems
Old May 9, 2009 | 10:55 AM
vincentl's Avatar
I just replaced my rotors (oem) and decided on some hawks pads. At first the brakes felt a lot better(after break in), but 5min into 5:00pm traffic they become extremely unreliable and they hardly respond under pressure.
It is creating some dangerous situations. I completely flushed the brakes 2 times and nothing seemed to improved. Also... under very heavy braking (in which i assume the abs turns on) there is a loud electrical pump sound followed by a bubbling sound. I've never heard a ABS module sound that way...
Any suggestions are appreciated.
Old May 9, 2009 | 11:38 AM
waijai's Avatar
i.love.gold
Hmm, did you remember to re-cap the brake fluid reservoir?
Old May 9, 2009 | 05:28 PM
vincentl's Avatar
Yep, is capped and the fluid does not seem to be leaking.
Old May 10, 2009 | 07:58 PM
EldinsG35's Avatar
I've had the same issues with Hapwk HPS pads. I almost rear ended a lady going 70 when she pulled out in front of me, but @ the last second the pads finally warmed up n stopped my car. Switch your pads and reflush your fluid with Dot 4. The pads I am running is Project Mu B force and they are very good, but dusty and noisy is the draw back. I am running ATE Dot 4 racing fluid. Hope that helps.
Old May 10, 2009 | 10:48 PM
vincentl's Avatar
Thanks for the advice. I'll give anything a shot at this point. I'm more concerned with safety and performance than noise and dust.
Old May 11, 2009 | 02:42 PM
EldinsG35's Avatar
^^^ I feel you man. I am the same way about safety.
Old May 11, 2009 | 02:44 PM
twin001's Avatar
I can vouch for the Project Mu B-force pads too. Excellent bite when cold or hot, they are just a little squeeky below ~30mph though.
Old May 11, 2009 | 07:19 PM
vincentl's Avatar
I bought it with XS/D rotors...should a go for OEM? *non brembo
mike730
Jan 12, 2018 04:25 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
saskicker32
Aug 11, 2015 02:12 PM
MsFitFern
Aug 9, 2015 02:58 PM
Lsantana757
Jul 20, 2015 09:08 AM
