clicking noise from rear brake
Old May 11, 2009 | 08:47 PM
MikekiM's Avatar
hello everyone!
it's been 2 weeks since i had the rear brake pads replaced but there is a clicking sound coming from only the left rear brake. the clicking sound only appears at certain time and when the brakes are applied.
anyone else has the same clicking issue? any feedbacks or suggestions will be greatly appreciated
mike
Old May 11, 2009 | 09:50 PM
spinna001's Avatar
I have the same problem
Old May 12, 2009 | 12:50 AM
Canadian's Avatar
Canada, eh?
Are you sure it is only when you are braking and not coming from a stop? If you are AT does it do it when you shift into gear?
Old May 12, 2009 | 01:09 AM
MikekiM's Avatar
yeah, only when i applied the brakes. no problems with my transmission. it's pain in the *** since it comes and goes. i got a feeling as soon as i hit the dealership, the sound will not appear.
Old May 12, 2009 | 01:17 AM
JBF's Avatar
JBF
check your rear hub assembly...or bearings
Old May 12, 2009 | 12:45 PM
Canadian's Avatar
Canada, eh?
I asked because it has nothing to do with the transmission, but with your axles. There is a TSB for our cars where a clicking sound comes from the rear axles when shifting into gear and accelerating.
Old May 12, 2009 | 01:38 PM
MikekiM's Avatar
i wish that was the issue but in my situation, it only occurs when the brakes are applied and as soon as i release the brakes, it stops...thanks canadian
Old May 13, 2009 | 09:44 PM
djkace77's Avatar
Do you have slotted or blank rotors? Maybe one of the metal clips on the caliber bracket is touching the rotor.
Old May 14, 2009 | 12:25 AM
MikekiM's Avatar
i have the oem blank rotors with aftermarket brake pads. i went to the dealer and they blamed the aftermarket brake pads but these are the right pads for my year (2005).
Old Jul 23, 2010 | 10:47 PM
ks112's Avatar
hi everyone, I have an 05 coupe and have the same brake clicking issue (continues click when the brakes are applied at low speed). I took it to the dealer once, they serviced the rear brakes and that fixed the noise for 2 days. Now the noise is back but only happens after 5-10 min of driving. Does anyone know the cause of this yet? The dealer has recommended resurfacing the rotors but that doesn't really make any sense to me as I don't feel any vibration.
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
papo020
Jul 17, 2015 10:30 PM
emorehs
Jul 17, 2015 09:45 AM
