Spacer/ Fitment gurus. Chime in
Old Jun 7, 2009 | 01:26 AM
Blackmouf's Avatar
I popped on some 15mm spacers in the front. What do you think of the fitment?
Too much? just right? Of course it needs a drop but as far as sitting flush, am I on the right path?
Front:
What do you think about the rear? Add or 5mm or leave it?
Rear:
Thanks for the help
Old Jun 7, 2009 | 01:32 AM
JAYY-G35's Avatar
Man i totally 4got to look at your spacers. lets see some pictures of the car in the garage.
Old Jun 7, 2009 | 01:35 AM
Blackmouf's Avatar
Lol not helping...... Im going to photoshop that out.
Here are the pics
https://g35driver.com/forums/other-c...dads-ride.html
Old Jun 7, 2009 | 07:37 AM
Blue Dream's Avatar
I drove ttrank's car solo
For my taste a little less in the front would look better, back is perfect!!
Old Jun 7, 2009 | 10:05 AM
Deftronix's Avatar
You might want to hold off on making anymore decisions about spacers until you get your car sitting exactly where you want it since you mention you want to go lower. The more you lower it the more the wheels will tuck. Of course this can be fixed with camber adjustment but it just all depends the look your going for so I would suggest you wait until you lower your car where you want and then figure out what size spacers you need. I would also recommend you get aftermarket toebolts and endlinks for your rear and a arms for the front so you can adjust camber to your liking. The reason I mention this is because your toe looks to be quite off on that overhead shot looking straight down on the rear wheel. Anyway, I think your spacers for the front will fit perfectly once you lower the car a little more. Nice car collection by the way
Old Jun 7, 2009 | 09:40 PM
xx7sephiroth7xx's Avatar
G
^ +1 I would wait until you get some coilovers/springs and are at the height you want.
Your rims will tuck in more once you drop it so there's no point in making it flush now if you're going lower later.
Props to your pops for that Ferrari in the garage.
Old Jun 7, 2009 | 10:55 PM
GreenGoblin's Avatar
The goblin resurrection
yup def drop it then deal with the spacers.
Old Jun 8, 2009 | 12:08 AM
OCG35's Avatar
+1, thats what I kept trying to look at... the lion statue is cool too...
Now, what was his question?...
Old Jun 8, 2009 | 12:14 AM
ShanesG's Avatar
Def drop it first denzel, it, will look alot less flush when you go lower!!!
Old Jun 8, 2009 | 12:24 AM
Skaterbasist's Avatar
Retired SuperMod
First, you are asking a subjective question when it comes to proper fitment. You're the one who decides what looks aggressive and what not.
And like everyone else has said, a drop would have been the better first step. When you drop the car, the wheels tend to look a little more sunken in due to the increase in negative camber. Once its dropped, you would have a better idea of what might be a better size spacer depending on what camber settings you want to run.
-Henry
Old Jun 8, 2009 | 12:29 AM
Blackmouf's Avatar
Thanks for the all answers and help.
I jumped the gun.....
Old Jun 21, 2009 | 02:59 PM
OtisG35's Avatar
Car looks damn clean! Front sticks out a little too much.
Old Jun 21, 2009 | 03:01 PM
patman530's Avatar
^^ i disagree, the front is just fine imo. just needs a drop. there are many people running much more aggressive setups than that in the front.
OP - it may help if you post up your wheel, tire, alignment specs, and what you plan to do with suspension/ride height, etc.
Old Jun 21, 2009 | 03:07 PM
infiniti g's Avatar
i think it looks good, and i see a 360 hiding in that garage
Old Jun 21, 2009 | 04:29 PM
OCG35's Avatar
Here are the pics
link in the post above
KruZZe
Feb 27, 2023 05:04 PM
magnetism80
Jan 27, 2016 12:57 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
the93owner
Oct 4, 2015 09:40 AM
DRG35R
Sep 16, 2015 05:33 AM
