Front knocking/popping sound
Old Jun 10, 2009 | 11:51 PM
MM2K4's Avatar
Hm...
so just noticed it today when was i was driving...i get this knocking/popping sound from the front passenger side suspension (i think)...i can hear it when i go through dips, uneven road, and even on flat roads, kinda of awkward...
I have a hunch its bad compression rod bushings, but I wanna see wut others think....
Oh ya..i have the following suspension mods: hotchkis sways, SPC camber kits, and tanabe coils
any feedback is appreciated :P
Thanks!!
Old Jun 11, 2009 | 12:36 PM
MM2K4's Avatar
hm...so weird...when i was driving today..the noise was gone....any ideas?
Old Jun 11, 2009 | 02:42 PM
Yosef's Avatar
are you sure it wasn't the passenger side seatbelt?
Old Jun 11, 2009 | 03:54 PM
MM2K4's Avatar
ya im pretty sure dude...i had a passenger..
its weird...cause i could feel it in my pedals when i hear the sounds....
Old Jun 11, 2009 | 04:58 PM
KSWAY's Avatar
It's probably your sway bar end links going out. I had the same thing happen to mine a while back. clunking when driving over uneven road. It went away and i was all happy. But it came back a couple days later. it ended up being my sway bar end links.
Old Jun 11, 2009 | 07:02 PM
MM2K4's Avatar
hm..i guess its recommended to go after market endlinks after upgrading the sway bars eh?
Old Jun 15, 2009 | 06:44 PM
tilmonr's Avatar
I just got the suctec pro5 and I hear a popping noise when I start braking. Do you have that same problem?
Old Jun 20, 2009 | 04:14 PM
alfhasg35's Avatar
crap...! okay . i just got new "REAR" tires yesterday and on the way home i got the same noise/sound... and i could feel it in my pedals too... it sounds pretty bad and sux cuz i just bought some new toyo;s with money i don't have.. anyone have any clues as to what it is..?
im on the forums..
so far i see compression rods, sway bar end links, or something to do with the driver side door not being alligned..>>???
o yeah i just have stillen sways, stillen stb and toyo t1r's on stock wheels 225/40/19 front and 255/40/19 rear...
i'm taking it in to the dealer tomorrow so i will update. damn car just outta warranty.. 61k miles
Old Jun 24, 2009 | 11:57 AM
alfhasg35's Avatar
Angry
im on the forums..
okay.... i took it to the dealer on monday the 21st... i forgot that my car has 61,750 miles... OUT OF WARRANTY ...
I thought that they would be able to hear/feel the clunk, and tell me what it was, maybe they might have heard it before.. but..as we all know... the dealer is all about the money..they asked me if the car had been in an accident... it never has... but that's kinda what it feels like.. n e how.. they want $135 an hour to find; not fix; the problem... i figured i would just take it to someone else since i know i am not going to let the dealer fix it anyway...
So I am goin to STILLEN today and see what they say.. STILLEN is like 10 min from my house... anyone suggest taking to anywhere else in Orange County...?????
By the way ... i've been driving my car like a grandma and the clunking has stopped all together.. i don't want to agitate it.. the car drives straight, it doesn't veer off the road when i take my hands off the wheel, but if i turn quickly left or right or hit a speedbump it has a terrible knocking/clunking sound...
Old Jun 25, 2009 | 09:08 PM
alfhasg35's Avatar
i took it to stillen and the tech test drove it....
NO NOISE !!!!!! NO KNOCKING<<<!!!
It stopped all together..
i don't know if that is good or bad..!
Old Jun 30, 2009 | 04:06 PM
spinn's Avatar
I've got a similar noise. Usually notice it goin up a driveway or over a speed bump. I was thinking its the suspension bump stop or something, but maybe it's the sway bar end links.
What's a recommended brand for after market end links?
Old Jun 30, 2009 | 04:12 PM
lil_will's Avatar
watching.
Old Jul 5, 2009 | 01:39 PM
MM2K4's Avatar
its weird...that knockin/popping sound has gone away....
however, when i drive up steep drivewys or go onto curbs...i still hear the slight knock..but that has always been there...
Old Jul 5, 2009 | 02:40 PM
Row2k's Avatar
20 Year Member
G35 Coupe
its your compression rod / lower control arm. Common problem, run a search
Old Jul 10, 2009 | 07:37 PM
05Scoobyroo's Avatar
I had the same issue, and ended up needing poly grease on the sway bar bushings, as I initially used lithium grease and it washed out. If there is an issue with your endlinks, you will only hear it once there is a load differential (going through a turn) between endlinks.
