how to lower your G properly!
Old Jun 12, 2009 | 12:01 PM
laksjd84's Avatar
Which spring lowers the G coupe by approx. 1 ~ 1.5 inch on front and rear without using any other aftermarket pats such as camper, shock and other suspension parts? i know im a big noob when it comes to suspension. help me out ya'll. thanks in advance.
*oh yeah, i know you can use revised 350Z springs, but nah..its barely noticeable. I want about 1 ~ 1.5 inch drop.
Old Jun 12, 2009 | 12:58 PM
Silencer_0's Avatar
If you want it done "properly", a drop over 1" pretty much requires a camber kit, and eventually better shocks down the road, unless you want premature tire wear....
As for lowering, I decided to go with coilovers instead so I could change to my desired height and dampening at any time. For springs, I think the Tein S-Techs lower over an inch.
Old Jun 12, 2009 | 12:59 PM
redlude97's Avatar
there is no such thing
Old Jun 12, 2009 | 01:24 PM
Calvin's Avatar
Overglorified Altima
no drop requires a camber kit.
but you'll want a camber kit if you want your tires to last (longer).
Old Jun 12, 2009 | 02:45 PM
fresh_06'G35's Avatar
check out eibach pro kit, lowers a lil more than an inch. im happy with mine and the ride quality is great! if u want a bigger drop go for the eibach sportlines. either way your gonna want a camber kit unless you like buying tires all the time$$$$$
Old Jun 12, 2009 | 03:04 PM
laksjd84's Avatar
thanks, can you suggest me a camber kit? brand and where to buy? thanks
Old Jun 12, 2009 | 03:05 PM
laksjd84's Avatar
laksjd84's Avatar
Old Jun 12, 2009 | 06:30 PM
Skaterbasist's Avatar
Retired SuperMod
Sounds like you have a long way to go before you make the right decision. Research is key, and im sure you haven't done much of it.
Old Jun 12, 2009 | 10:43 PM
i have the SPC kit front and rear, got the job done no hassles. check out the marketplace theres plenty of other good kits for sale.
Shrummi's Avatar
I'm dropped on espelirs ASD springs. I'm about 1.5 inches dropped haven't installed a camber kit but am now starting to swap my tires. It took 20k miles before the camber smoothed one side of each tire out. now i'll swap em and get some more mileage out of em. Just make sure to get a proper alignment after dropping it.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
