What size wrench to unbolt front calipers on '06?
Old Jun 29, 2009 | 08:23 AM
Mustang5L5's Avatar
Attempted to replace my pads and front rotors this weekend but got hung up on the two large bolts holding the caliper to the spindle.
Anyone know what size wrench it is? I think it's metric. I didn't have one that big.
I tried an SAE wrench but it fit loose and I was afraid of damaging the bolt since it was pretty tight so I didn't try to hard.
Old Jun 29, 2009 | 08:40 AM
KSWAY's Avatar
I think it's a 17MM.
Old Jun 29, 2009 | 08:41 AM
Vrod-Mike's Avatar
My 05 uses a 19mm
Old Jun 29, 2009 | 08:43 AM
Mustang5L5's Avatar
19mm sounds about right. I think I had a 3/4" wrench on there and it was slightly loose.
I think I have a 19mm somewhere too
Old Jun 29, 2009 | 08:45 AM
KSWAY's Avatar
Damn is it 19mm? I thought it was 17mm.
Old Jun 29, 2009 | 08:46 AM
Mustang5L5's Avatar
Actually I think we are all wrong.
http://www.nicoclub.com/articles.php?id=220764
That site says it's 22mm
Hmm, maybe it was a 7/8" wrench I had on there. Now i'm confusing myself
Old Jun 29, 2009 | 08:56 AM
KSWAY's Avatar
I can't imagine it being 22mm. But it's been awhile since I changed my brake. Can't you go to like Auto zone and get loaner tools?
Old Jun 29, 2009 | 09:05 AM
Mustang5L5's Avatar
I remember it was big. I had up to 1" SAE wrenches and can remember it was either a 3/4" or 7/8" wrench i had on there.
I have up to 22mm wrenches at work, so just borrowed a 22mm.
It was also tight as hell. That's why i didn't try to hard with the standard wrench since it was slightly loose
Old Jun 29, 2009 | 10:24 AM
lexusk8's Avatar
For my 03.5 sedan, it was either a 17mm or 19mm socket for the torque member bolts on the front caliper. A breaker bar makes life easier when breaking these bolts loose. If you haven't done so yet, turn the wheel outwards to allow yourself more headroom and space in removing the bolts.
Old Jun 29, 2009 | 10:29 AM
Mustang5L5's Avatar
Cool
Rotor slips off after that right? Pretty sure it does
Old Jun 29, 2009 | 10:41 AM
lexusk8's Avatar
Yep the rotor should come right off after the caliper and bolts are removed. If it doesn't, tap the rotor out with a rubber mallet (or you could spray the area behind the rotor with PB Blaster and hammer the rotor out).
Old Jun 29, 2009 | 12:13 PM
Vrod-Mike's Avatar
The rotor won't come right off. It will be stuck on. Use some PB Blaster to loosen the rust then give it a few whacks. The front rotors have the access holes for the special rotor removal tool if you have one.
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
