Do I need to cut the rear for the SPC kit?
Old Jun 30, 2009 | 04:44 AM
Silver5656's Avatar
My rears are currently set up perfectly. If I get the front/rear kit, do I need to drill the holes for the rear? Or can I just swap them in?
Old Jun 30, 2009 | 05:03 AM
oyoquem's Avatar
What do you mean your rears are set up perfectly? As far as the SPC rear kit goes they bolt right in. I'm assuming you are talking about the camber arms and not camber bolts. The only cutting is for the toe if you are installing the bigger toe bolts. You may need to elongate the holes for the toe bolts.
Old Jun 30, 2009 | 10:55 AM
Vrod-Mike's Avatar
When you install the rear toe bolts you have to elongate the factory holes, but since the subframe is aluminum it's pretty easy.
Old Jun 30, 2009 | 11:28 AM
ttrank's Avatar
Grocery getter
If you are "set up perfectly" why are you bothering?
Old Jun 30, 2009 | 11:49 AM
GreenGoblin's Avatar
The goblin resurrection
If you buy the spc rear kit, you will never get the correct range for adjustment unless you slot the holes.
Old Jun 30, 2009 | 12:07 PM
mr2willwin's Avatar
anyone have an example of this? I have the kit too, but haven't put it on yet knowing there was something to be done. Did you guys just use a dremel?
Old Jun 30, 2009 | 12:40 PM
Vrod-Mike's Avatar
Here's a pic of when I did mine. A dremel would take forever. I used a die grinder and a heavy rasp bit and each hole only took a few minutes.
Old Jun 30, 2009 | 01:50 PM
mr2willwin's Avatar
Thanks for the pic, that makes sense, If I do it at home, my only option is a dremel
Old Jun 30, 2009 | 04:15 PM
Vrod-Mike's Avatar
You will be there for a long time. I hope you have a lot of patience. LOL
Old Jun 30, 2009 | 04:20 PM
Not true if you buy the correct bit for a dremel. I used a rasp with alum bit, but is 100% do-able with even a file.
Old Jun 30, 2009 | 04:29 PM
ShanesG's Avatar
I use a dremel and it takes about a min for each side with a #115 bit!
Old Jun 30, 2009 | 05:08 PM
redlude97's Avatar
Those cut aluminum like butter
Old Jul 1, 2009 | 05:03 AM
Silver5656's Avatar
the rears are set up currently w/o any spc kit to my liking, and am only getting the rears because of the combo kit that is currently on sale. I only need the fronts, but want to get the rears as well in case I choose to change my rear settings. So does this mean that I do NOT need to do any cutting as I only want to basically swap the stock camber arms with the spc camber arms?
Old Jul 1, 2009 | 05:22 AM
oyoquem's Avatar
Same bit I use. OP make sure you wear proper protection. Safety glasses, gloves, and mouth. Fine pieces of aluminum can get in your eyes easily. Not too difficult with the proper tools.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
nascarbuff17
Jul 16, 2015 10:23 AM
