Any one replace their lower ball joints?
Old Feb 10, 2010 | 05:58 PM
  #46
Jeff92se's Avatar
Red Card Crew
Originally Posted by str8dum1
of course you can replace them, the problem is getting one by itself that doesnt cost more than the entire arm assembly from nissan
Might be right. Ebay ones are $60 each.
Old Feb 10, 2010 | 06:57 PM
  #47
GT-ER's Avatar
The ones Z1 sells are modified for lowered cars and cost over $300 I believe....YIKES!
Old Feb 11, 2010 | 12:17 PM
  #48
waijai's Avatar
i.love.gold
Originally Posted by ddenunzio
When I turn into my driveway I hear a creaking noise like a loose floor board in an old house. Is that the sort of sound that is related to a ball joint or compression rod or both? Not really a mechanic but I have the service manual and willing to try pretty much whatever as long as the job doesnt require any repair shop level machinery or any thing I cant borrow from autozone. Any ideas?
May be your sway bar end links. Mine creaked when they started to go bad.
Old Feb 18, 2010 | 05:28 PM
  #49
blAk mAx's Avatar
updates?
Old Feb 18, 2010 | 10:02 PM
  #50
GT-ER's Avatar
Originally Posted by blAk mAx
updates?
Not yet, I have yet to recieve them.
Old Feb 23, 2010 | 10:50 AM
  #51
sibubble92's Avatar
I have receive mines today I'll post pictures up later they look like they are the right ones
Old Feb 23, 2010 | 07:15 PM
  #52
blAk mAx's Avatar
pictures !!!!!!!! maybe a side by side pic
Old Feb 23, 2010 | 07:24 PM
  #53
Jeff92se's Avatar
Red Card Crew
You won't really know until you pull your oem out but good luck!
Old Feb 23, 2010 | 08:50 PM
  #54
GT-ER's Avatar
Apparently mine are in my pobox waiting for me to get them. I'll try and see if tomorrow I'll pick them up and install them.
Old Feb 23, 2010 | 09:44 PM
  #55
sibubble92's Avatar
i just finish installing them they work great
Old Feb 23, 2010 | 10:18 PM
  #56
blAk mAx's Avatar
how long was the install? did you leave the knuckle on while you pressed them in ?
Old Feb 24, 2010 | 07:45 AM
  #57
sibubble92's Avatar
no i took it out is not as hard as it looks to take out took me and a frien of mine like 45 min to change the ball joint, the front rotor and brakes... here is some quick pictures Name:  photo-2.jpg
Size:  93.0 KB Name:  photo-3.jpg
Old Feb 24, 2010 | 10:15 AM
  #58
blAk mAx's Avatar
Thanks. I'll have to order when I get home. Did you use a balljoint press and table vise ?
Old Feb 24, 2010 | 01:47 PM
  #59
Jeff92se's Avatar
Red Card Crew
Did you happen to check the old one to see if there was excessive play or if it was moving around much easier than it should? And can you measure the OD of the part that gets installed into the suspension? That way we can see if the Z32 300zx ones will fit also. They certainly look similar. Great work!
Old Feb 24, 2010 | 02:32 PM
  #60
sibubble92's Avatar
The old one had alot of play in it it was really bad I been bad for over a year cuz I couldnt find a separate ball joint for it
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
