Which Strut Bar?
Old Jul 28, 2009 | 01:24 PM
irishsig's Avatar
Which Strut Bar?
I've done a lot of research but have come across a lot of conflicting info.
I'm basically looking for your opinions on the best strut bar that matches the following requirements.
1. around $200
2. will clear a 5/16 spacer
3. won't rub the hood liner
4. won't interfere with anything else under the hood
5. actually improves handling/less body roll
Any ideas, thanks guys.
Old Jul 28, 2009 | 01:31 PM
CandlestickPark's Avatar
ill Sedan
Based on your criteria check out the GTSpec strut bar, I've heard good things about it. I have the NRG strut bar, but after hearing comments from people who've owned both it sounds like the GTSpec is the way to go (sturdier than the NRG bar).
If you are looking to reduce body roll though you may want to look into a set of sway bars versus a FSTB, will cost more than what you've budgeted, but they will have more of an affect in this area over a FSTB.
Old Jul 28, 2009 | 01:44 PM
irishsig's Avatar
Thanks Candlestick. Yeah that's definitely on the list.
The trick is figuring out if I still want an aftermarket exhaust and which one won't interfere with which sway bars.
I kinda want the engine bling too.
Old Jul 28, 2009 | 02:12 PM
Deepdiver's Avatar
stay with the GTSpec. It's sturdy, adjustable, and looks great. It will def clear your spacer. Unfortunately mine rubs the liner a bit, however others have said theirs do not.
Old Jul 28, 2009 | 02:52 PM
irishsig's Avatar
Okay, GT Spec it is.
Anyone know if the NRG Ritchie Ver2 rubs against the hood liner?
Old Jul 28, 2009 | 04:12 PM
Deepdiver's Avatar
^ yes, it seems as though it does.
Old Jul 29, 2009 | 12:06 AM
vq35dedriver's Avatar
mine kinda did you can see it on the liner and I had it at the lowest setting
nice bar IMO, definately helped with conering and sturdiness sold mine though
Old Aug 2, 2009 | 01:06 PM
PTownG's Avatar
Thumbs down
It definatly does. On mine it even bulged the hood despite the fact that I have no spacer or engine cover and had the bar set all the way down in the brackets.
Besides that is it cheap hollow aluminum that you can flex with your bare arms. How the hell is that going to add any rigidity to the front end?
Old Aug 2, 2009 | 02:00 PM
JSpec350GT's Avatar
There is a one piece strut bar made by Circuit Sports. I do really like its construction but it looks ugly. I'm thinking of selling my Ritchie to buy that.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
