crazy suspension noise. ouch chawlay
Old Aug 14, 2009 | 04:36 PM
bbs350z's Avatar
my suspension up front makes a god awful noise over every bump it hits. its loud, obvious, and obnoxious. also when i apply the brakes briskly it makes the clunking noise.
i can also get the noise when im stopped, and i release and press the brakes quickly. its a clunking/bouncy noise almost. i can get a video if thatd help. any idea what it is? i already replaced my shocks w/ s techs and my stock z's struts, which didnt help at all
Old Aug 14, 2009 | 06:38 PM
Polaren's Avatar
Sounds like compression rods due to the clunking with touching the brake.
It's easy to see outside of the car, have someone do it in the car while you stand outside and you'll see it. The wheel will actually move forwards and backwards.
Had the same thing..replaced both compression rods and all good. (usually it's the bushing that goes in the compression rod which is sold separately)
Old Aug 14, 2009 | 10:03 PM
bbs350z's Avatar
link to buy compression rods? how tedious is it to replace? thanks for the quick reply btw
Old Aug 16, 2009 | 01:46 AM
Choleaoum's Avatar
bump in on one
Old Aug 16, 2009 | 01:52 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you have a sedan it's an easy replacement. Coupe is a little more involved as the cross-member bolts up under the compression rod. Either way it's pretty straight forward.
-GP-
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
