Motordyne Adjustable Sway Bars for the 350Z and G35.
Old Jan 6, 2010 | 02:31 PM
  #106
Calvin's Avatar
Overglorified Altima
^^^Mine are coming today.
I hate waiting for FedEx. They don't typically get to my neck of the woods until late afternoon/early evening.
Old Jan 6, 2010 | 02:39 PM
  #107
Johnnyone's Avatar
Originally Posted by Silencer_0
^ You got the first set and you still havent installed them?? Lol
You won't be disappointed . Turning is a lot more fun now
I agree and i'm getting more and more comfortable driving the car hard. Can't wait to see how the car handles with some good coilovers.
Old Jan 6, 2010 | 03:47 PM
  #108
Calvin's Avatar
Mine just arrived.
Old Jan 6, 2010 | 06:07 PM
  #109
Calvin's Avatar
Will be installed tonight.
Tony, can you explain the pros and cons of solid sway bars over hollow ones?
Also, what exactly is the diameter of the front/rear bars?
Old Jan 6, 2010 | 06:31 PM
  #110
idrive_MD's Avatar
I think they say there is a 5% loss of stiffness from going from solid to hollow, so those seeking weight savings would say its worth to go hollow as it could be as much as a 3-15lb weight savings depending on the bar thickness. Solid is also probably a little more stronger and less likely to break I would guess.
Cost wise, I doubt there's much difference unless of course they use a mandral to bend the tube-stock.
Old Jan 6, 2010 | 06:41 PM
  #111
Silencer_0's Avatar
Nice! What stiffness are you gonna set it too?
Old Jan 6, 2010 | 07:04 PM
  #112
Hydrazine's Avatar
Solid bars are stiffer. Certaintly more than 15% stiffer. And for more than anything, better (chrom-molly) alloys are available in bar.
Old Jan 6, 2010 | 07:05 PM
  #113
Calvin's Avatar
hard front med rear
Old Jan 6, 2010 | 07:06 PM
  #114
Hydrazine's Avatar
Are you running stock bars right now?
Old Jan 6, 2010 | 08:15 PM
  #115
Calvin's Avatar
Yep. OEM non-sport suspension.
Old Jan 7, 2010 | 12:03 AM
  #116
Johnnyone's Avatar
hard front med rear
Let us know how that handles. i have mine set at med front and hard in back. 2 me my steering seems more responsive.
Old Jan 7, 2010 | 01:00 AM
  #117
Silencer_0's Avatar
Mines set at med/med lol
Old Jan 7, 2010 | 03:39 AM
  #118
Footballmania32's Avatar
Hello. I need lots of advice with sway bars. I've read up a bit on them and I have a pretty good idea of what they do. How do you adjust the stiffness on these particular bars? And also, are they relatively easy to install? I want to start on suspension before moving onto other projects, are sways a good start?? Just got my coupe a month ago and the mod bug bit pretty hard.
Old Jan 7, 2010 | 03:53 AM
  #119
Dranom's Avatar
is it possible to get the sways in a different color?
Old Jan 7, 2010 | 05:21 AM
  #120
xx7sephiroth7xx's Avatar
G
Well, you can always sandblast and re-powdercoat...
