Time to buy front camber arms
Old Jan 19, 2010 | 10:13 PM
  #46
813G-WHiP's Avatar
my front fenders are 24 and 3/4'' from the ground and the rears are 25 and 1/4''
Old Jan 19, 2010 | 11:14 PM
  #47
HwyDrftr's Avatar
Those look like the Ichiba's, I like the design except for the 6 set screws, what a pia
Originally Posted by JOKER
AARONHL
Looka hea
It looks to me that this guy is using the product you speak of.
His UN is obby
Old Jan 20, 2010 | 01:07 PM
  #48
813G-WHiP's Avatar
I read that the spc gives a range of -1.5 to +3.5. Do the spacers give you +2.5 degrees camber?
Old Jan 20, 2010 | 01:09 PM
  #49
AARONHL's Avatar
I'm lowered a little over 1.5 inches. My front left camber is -1.25 and my front right camber is -1.66. So, there would be no reason for me to install the additional spacers?
Old Jan 20, 2010 | 01:10 PM
  #50
Gdup35sedan's Avatar
ENVautoDetailing.com
The arms give you one full degree. The spacers give +2.0 degrees.
  #51
is that before or after the alignment?
Old Jan 20, 2010 | 01:32 PM
  #52
AARONHL's Avatar
After.
Old Jan 20, 2010 | 01:39 PM
  #53
That's pretty good. The cross camber is more than i've seen on a G but it's not that bad at all. As long as the car doesnt pull, you'll be perfectly fine.
Old Jan 20, 2010 | 01:43 PM
  #54
AARONHL's Avatar
So there is no adjustment for camber?
Old Jan 20, 2010 | 01:46 PM
  #55
If you've already maxed out the camber, no. You can add some negative camber to the left side to make it even with the right. But if it's not pulling, then there is no reason to do so.
If you leave it as is, i would flip your tires every 10k miles if they're directional. If they are assymetrical, you can just swap them side to side every 5k and get even wear.
Old Jan 20, 2010 | 01:51 PM
  #56
AARONHL's Avatar
Do you add negative camber by adjusting the tie rods?
I barely rotate my tires, but will start when I get my suspension STRAIGHTENED OUT.
Old Jan 20, 2010 | 01:54 PM
  #57
No, tie rods adjust your TOE. You adjust camber by loosening the 27mm nut on top of the SPC A-arm, then you'll push it towards the center of the car just a tad, then tighten the nut back down. But that is going to mess up the toe so you'll need to get another alignment done. I would just leave it as is.
-GP-
Old Jan 20, 2010 | 01:57 PM
  #58
AARONHL's Avatar
How do you adjust camber without aftermarket A-Arms?
Old Jan 20, 2010 | 01:58 PM
  #59
You dont. There is NO adjustment. Only the rear camber can be slightly adjusted from the factory via eccentric bolts in the sub-frame.
I got the impression that you already had the SPCs installed. If you dont, then you'll be fine with just the arms. No need for the spacers as that would put you in to positive camber numbers which is a big no no on any sports car.
Old Jan 20, 2010 | 02:04 PM
  #60
AARONHL's Avatar
Thanks for everyone's time in this thread, I am learning a lot!
You said you could adjust camber more negative to match the other side, how do you do that?
