Time to buy front camber arms
Old Jan 25, 2010 | 02:15 PM
  #106
OCG35's Avatar
Originally Posted by AARONHL
Would the 350EVO arms be one of the best choices for me? My G just needs a little more positive camber...
no not those...
If you can find SPL V-1 those probably have the most adaptability (including positive camber)...
Most A-Arms are going to give you plenty of negative camber, but not too many adjust very far positive.
How far positive do you need to go?
Old Jan 25, 2010 | 02:28 PM
  #107
AARONHL's Avatar
No more than +0.7°...
Old Jan 25, 2010 | 02:57 PM
  #108
OCG35's Avatar
1/2 degree?...
Are you trying to get in spec? Or is there another reason?... 1/2 degree isn't munch to worry about typically...
Old Jan 25, 2010 | 03:00 PM
  #109
AARONHL's Avatar
Yea, I would like to get within the factory setting.
To keep the conversations going:
http://cgi.ebay.com/ebaymotors/KSPOR...Q5fCarQ5fParts
Old Jan 26, 2010 | 01:28 AM
  #110
Gdup35sedan's Avatar
ENVautoDetailing.com
Those K-sports look like a similar build to the Kinetix which are known for breaking at the welds. Notice how the 350evo and the SPL V2's do not have welds in them... anywhere. They are 2-4 seperate pieces (depending on which one and both including the ball joint) that are all "bolted" together and not welded. There is an immense amount of stress being put on your A-Arms at all times while driving and the welds dont always hold up...
Old Jan 26, 2010 | 06:06 PM
  #111
gq916's Avatar
So, whats the cheapest camber kit that I can buy and from where? Im only worried about my tires going bald, not worried about anything else. My car is lowered 1.5" front and 1" rear. Thanks guys
Old Jan 26, 2010 | 06:10 PM
  #112
OCG35's Avatar
you're not worried about welds breaking with going 60mph?... and you're not worried about adjuster plate coming loose while taking a sharp turn?
I couldn't give you a suggestion, because I think you are overlooking critical issues in order to save a couple bucks.
If you are looking for a "reasonably priced" A-Arm that is relatively reliable - there are a few... but "cheapest" with no other consideration = trouble.
Old Jan 26, 2010 | 06:21 PM
  #113
gq916's Avatar
what i meant to say was the cheapest one that will work without problems, and how hard are they to install at home? i saw a DIY online from stillen. Check out the link. Is all of this really required to get to the camber kit?
http://blog.stillen.com/installation...-installation/
Old Jan 26, 2010 | 06:50 PM
  #114
The cheapest without losing quality would be Ichiba. But it will not get you as much positive adjustment as SPC/SPL/350EVO.
Old Jul 9, 2010 | 01:39 PM
  #115
inda626's Avatar
Old thread
I know this is an old thread, but just threw in some ichibas on the front.. Only got +.1 of a camber difference from the OEM arms.. Was hoping to get back into spec, but no luck. I guess SPC, or SPL, is the way to go then, right? As of now, my camber on the left is 1.8, and the right is 2.1.. Anyone know if the knocking issue was ever resolved with the arms??
rezendvous420
May 31, 2020 01:26 PM
teamghost
Jul 28, 2015 04:52 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
