Weird "WHUURR" noise, sounds like brakes... happens when braking
Maybe you guys can help... before i start taking things apart!
First of all. my pads and rotors are not even 4 months old.
I got in my car this morning and while driving... it was fine. The second i engaged the brakes, i heard a faint "WHUUUURRR" from the front of my car, which appeared to get louder the faster i was going (when i engaged the brakes) and how hard i engaged them. When i drove it around for a little... it didn't happen every time. It happened.... 1/2 the time when i engaged the brakes.
I also heard it while braking & turning at the same time.
I inspected the rotors and my drivers side seems to have a deep groove on the outer part of the circle... so i am assuming that maybe a rock or something got stuck in between the pad and rotor?
Im going to pull the caliper & rotor apart tonight but i wanted to see what you guys suggested first. I read online that it may be a wheel bearing.. and to check, i should jack up the car and see if the wheels move in/out at all.
Any advice is greatly appreciated!
MyfistYourFace
Aug 8, 2015 11:58 AM
Wayne9011
Jul 27, 2015 11:25 AM
