camber question on 04 sedan
Old Feb 14, 2010 | 01:19 PM
VEEG35.0's Avatar
i want to get a camber kit for my car but i have i tight fit on the back wheels will a camber kit make me rubb the sides and i already have my fenders rolled ? and im on s-techs
Old Feb 14, 2010 | 01:22 PM
G35Papa's Avatar
A camber kit won't make you rub. A camber kit is made to give you more adjustability +/- over your stock camber arms. It sounds like you can't go more positive so arms won't really do you any good unless you want to go more negative. I would recommend getting toe bolts though.
Old Feb 14, 2010 | 01:47 PM
VEEG35.0's Avatar
toe bolts wills also save me tires ? cuz i just got some new tires fk452 all around and i want it to wear out even
Old Feb 14, 2010 | 02:02 PM
G35Papa's Avatar
Your going to want to get an alignment if you haven't already. Getting your toe back in spec is crucial to prolong the life of your tires, more so than getting camber into spec. What are the specs of your rims? tire sizes? Are you trying to achieve a certain look? Is getting back to OEM alignment specs a priority for you?
Not a knock on you but so many people drop first then worry later on about an alignment/the need for camber kits..etc. There's so much info on this forum that people should be well aware of what they are getting themselves into before they drop the car.
Old Feb 14, 2010 | 02:14 PM
VEEG35.0's Avatar
i dropped my car and got c19's the first month i had my car and i new what would happen with my tires but i liked the look and drive so i just kept it but i want to my tires as much as i can cuz the way i drive uses a lot of tire
and thank you for the info
Old Feb 14, 2010 | 02:15 PM
VEEG35.0's Avatar
c19s 255/40 245/35
Old Feb 14, 2010 | 02:19 PM
VEEG35.0's Avatar
https://g35driver.com/forums/media-s...first-pic.html
this is my car ^^
Old Feb 14, 2010 | 02:29 PM
G35Papa's Avatar
Have you already gotten an alignment to see how close to spec you are already? If you are dropped on sedan stechs (vs coupe/z stechs which will give you more of a drop) you should be able to come close to oem specs without after market parts in the rear.
Old Feb 14, 2010 | 02:37 PM
VEEG35.0's Avatar
its the coupe/z stechs the ones vlad had on his car klubbheads
Old Feb 14, 2010 | 02:47 PM
VEEG35.0's Avatar
and i didnt get an alignment yet i will be doin that tomaro i wanted to go to Precision Z Service what do u think
Old Feb 14, 2010 | 05:05 PM
VEEG35.0's Avatar
i just want my tire life to last longer but keep my drop and tire sizes
Old Feb 15, 2010 | 11:15 PM
G35Papa's Avatar
You will be able to get close to OEM spec but not exactly back to stock. If you want to maximize the tire life, you'll need camber kits. If it was me, I would just deal with the camber wear by flipping the tires from side to side every few thousand miles.
Old Feb 15, 2010 | 11:53 PM
VEEG35.0's Avatar
ok i got me the spc camber kit but not installed and i had an alignment done today i think the specs on the rear were -2.5
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
