Rear Camber Kit Didn't Work.. HELLLPPPP
Old Mar 13, 2010 | 11:46 AM
  #76
wreckshop56's Avatar
At sals autosport right now knocking out the toe bolts... As he said they had some installed but the actual bolt compared to the spc was so thin and my rear camber on the right tire was loose... So hopefully they get it right.
Old Mar 13, 2010 | 08:37 PM
  #77
Old Mar 15, 2010 | 08:35 PM
  #78
any thoughs?
Old Mar 15, 2010 | 10:46 PM
  #79
EL-EE-ES's Avatar
looks pretty good on the rear specs, not bad on the fronts
Old Mar 15, 2010 | 11:08 PM
  #80
money042's Avatar
Specs don't look too bad. Looks like a toe problem before, but it is fixed now. Camber is slight, but not out of the ordinary for the coupe. I'm still interested in how many miles you put on the car in the 6 months. You said 3 oil changes, how often do you change your oil? And those Nitto 555's are "ultra high-performance" summer tires. You'll get 12k-15k miles out of them, depending on your driving habits.
Old Mar 16, 2010 | 07:14 AM
  #81
probally about 6k miles in 6 months I have 3 other cars so I try not to drive it that much
Old Mar 16, 2010 | 07:25 AM
  #82
Yeah on the fronts he said I might need spacers to get it back to spec but it's not that bad
Old Mar 16, 2010 | 12:19 PM
  #83
Tollboothwilley's Avatar
I would check to make sure your control arm bushings are ok. You ate through those tires.
If just TOE is off, you'll eat through the whole tread not just inside. If camber is terrible, you can eat through just the inside or outside.
If your bushings are bad then you can eat the inside tread just like that.
Either way, driveability should be crazy. What did the shop say after they did the alignment? What did they say about not being able to get it back into spec?
Old Nov 3, 2010 | 01:05 PM
  #84
Mre G Pilot's Avatar
Originally Posted by kricci11
I agree with the toe theory -- i had a very similar problem running through 2 sets of brand new rear tires in less than 11,000 miles... my car has RAS so when the camber kit was installed, the original shop did not dremel out the toe bolt area and install the bolts - when i took my car in for an alignment, the shop fixed that issue and i haven't had any issues since.
How much material needs to be removed for the bolts?
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
