Akebono swap
Old Mar 27, 2010 | 10:32 AM
G35pwrd's Avatar
Akebono swap
Any thing I will run into installing the Akebono BBK to my 2005 G35x? I ordered the whole kit from a vendor. I am asking if there are any mods needed to be done aside from the dust shields.
Any info would be appreciated. Thanks!!
Old Mar 27, 2010 | 11:06 AM
BuckeyeInMI's Avatar
Gotta do some searching. https://g35driver.com/forums/brakes-...03-07-g-z.html
Old Mar 27, 2010 | 11:19 AM
G35pwrd's Avatar
Errr.. oops. My apoligies.
Old Mar 28, 2010 | 12:48 PM
No probs. That's a big upgrade, so I'd ask extra questions too before I jumped into it. Post up something after you're done so we can all see it. (I'm envious because I can't put this kit on my car - run stock 17's in the winter).
Old Mar 28, 2010 | 01:45 PM
G35pwrd's Avatar
Well I knocked it out yesterday by myself in about 5 hours, slacking and taking my time to read and re-read the article you linked me too. Unfortunately since I was the only one working on it, I was more focused on doing the work and doing it right, rather than documenting it with pictures. I did have help at the ended bleeding my brakes since it is easier with two people.
I would estimate that if I had a lift and multiple airsaw blades for cutting the dustshields, the job could be done in about 3.5 hours. 2 if you had two people working at the same time. It is an incredibably easy job to do.
Old Mar 30, 2010 | 12:49 AM
Fine, make me more envious why don't you!
And I wasn't thinking of another DIY from you, nothing that big. Maybe just add your thoughts on your upgrade to that DIY thread so others might benefit.
Now, where's that template I cut out? I'm sure if I measure it just one more time against those stock 17's, it will finally fit.
Old Nov 3, 2013 | 07:37 PM
GreySky's Avatar
Hey Guys,
Just wanted to post this up...I received my front adapter brackets for the Akebono BBK swap the other day from Fueled Racing (http://www.fueledracing.com) and these things are SWEET !
https://www.dropbox.com/s/txrnlrivrm0bme4/DSC_0041.JPG
Old Jun 20, 2014 | 04:39 PM
GreySky's Avatar
For anyone doing a repaint on the Akebono's and needs the lettering I just found this place...
http://www.acromann.com/product_info...d50j5rp4u8hfc2
Old Jun 20, 2014 | 04:52 PM
Urbanengineer's Avatar
Originally Posted by GreySky
For anyone doing a repaint on the Akebono's and needs the lettering I just found this place... http://www.acromann.com/product_info...d50j5rp4u8hfc2
Me gusta. These will look good on my red painted OEM sport brakes
/troll
Seriously though, that looks good... But we need you to test them to temperature cycles (getting hot and cold).
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
alessandro
Oct 8, 2015 09:29 AM
doakley92
Sep 25, 2015 12:58 PM
DG2Door
Sep 11, 2015 08:04 PM
