Installing Shocks
Old May 3, 2010 | 10:47 PM
klevr's Avatar
Installing Shocks
How hard is it to install shocks compared to installing springs? I've replaced the springs on my car myself but I'm not very knowledgeable when it comes to cars to begin with. I can't seem to find a DIY for this either. Anyone have any tips? I'll be installing 350z Tokico D-Spec's
Old May 3, 2010 | 11:16 PM
Texasscout's Avatar
If you can do springs, you can def do shocks. The toughest thing is to loosen/tighten the front upper rod nuts. There is a special tool that makes it easier (rent from auto parts store?) for this but you really don't need it. You just have to find a way to keep the rod still while you tighten the nut. The back ones are the easiest.
Here's the service manual for the Front supension: http://www.g35frenzy.com/downloads/2...nual/E/fsu.pdf
And the back: http://www.g35frenzy.com/downloads/2...nual/E/rsu.pdf
Old May 4, 2010 | 01:53 PM
A.Chambers's Avatar
Is it not just an allen wrench to hold the rod? I usually just use an impact gun to take that nut off, the fast impact hit of the gun will usually take it off without spinning the rod.
Old May 4, 2010 | 07:11 PM
Texasscout's Avatar
Yes, you can use an impact CAREFULY. The rod end just has a couple of "flats" for a wrench. There is a special socket that will do this, but I think it's a dealer only item.
Old May 4, 2010 | 07:53 PM
NachoCheese's Avatar
I just recently dropped my car on DF210 springs, and if you have replaced the springs on the front, it's the same thing. Just take em out again, and put the springs on the new strut, and replace em. Rear shocks looked super simple, too. I only did springs, though.
snic09
Nov 8, 2017 01:46 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
twining24
Aug 19, 2015 05:29 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
smartin0924
Aug 13, 2015 07:29 PM
