camber kit info
Old Jul 20, 2010 | 02:53 PM
bolacbolac's Avatar
camber kit info
is there a difference between different brands of camber kit??? I see on ebay SPC, Godspeed, TCS, Ichiba, Mega, Circuit Sport, noname... price varies between 50 to 180 $ + shipping
Old Jul 20, 2010 | 06:21 PM
Princedrama's Avatar
do a search
Old Jul 20, 2010 | 07:15 PM
Xet's Avatar
Xet
Search... buy an ichiba or spc and get the toe bolts too. If you don't trust what I say you are just going to have to do the searching.
Old Jul 20, 2010 | 07:58 PM
Blue Dream's Avatar
I drove ttrank's car solo
OP are you talking about kits for the front or rear?
Old Jul 20, 2010 | 10:41 PM
bolacbolac's Avatar
front and rear...
Old Jul 20, 2010 | 11:01 PM
Xet's Avatar
Xet
from his initial post he said up to 180+ shipping even if that just means above 180 that is far from the price of a good front camber kit.
but again to the op just search there are a billion topics telling you which kits are the best
Old Jul 20, 2010 | 11:07 PM
jrhykushi's Avatar
whats the difference between camber arms and kits? it seems like arms are wayy cheaper?
Old Jul 20, 2010 | 11:26 PM
Xet's Avatar
Xet
If you are talking about in the rears arms are just arms and kits include toe bolts. Toe bolts alone only sell for like $30-40 new so it shouldn't be that much cheaper without them. But if you are dropping enough to need camber arms you are going to need the new toe bolts and to elongate the hole or else you won't be able to get your toe back into spec along with your camber.
Old Jul 21, 2010 | 03:16 PM
bjquinnIUmed's Avatar
There are differences between the kits. I would not recommend Ichiba...the inward rubber bushing has been known to fail on them. Try Wicked for rears...spc if you're looking for fronts. Plus a set of toe bolts for the rears as well.
Old Jul 21, 2010 | 09:42 PM
Xet's Avatar
Xet
Do you have links for this "info"? If you run a search you will see how many people state that ichiba rears are rebranded spc. So how can ichiba rears have a problem and not spc?
And barely anyone recommends spc front camber kits, they are known to have problems with knocking if you get too low and they are difficult to install if you are doing the shims without ABS having a problem.
zoop425
Mar 29, 2016 05:51 PM
G4ORCE
Aug 22, 2015 01:16 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
