SPL camber kit making noises??
Old Sep 18, 2010 | 02:54 PM
Mr_pharmD's Avatar
ok I finally got a chance to get everything installed and now it makes a clump/thumping noise when I go over bumps or uneven roads. This only happens on the passenger side front. Sounds like I hit bottom when it happens.
Old Sep 18, 2010 | 03:45 PM
Invalid_User's Avatar
I have the exact same sound except on the drivers side. I didn't pay almost 500 for these things to make noise like that.
Old Sep 20, 2010 | 01:12 AM
Mr_pharmD's Avatar
ya, my friend has it on the driver side also. I'm like wtf.
Old Sep 20, 2010 | 01:15 AM
JBF's Avatar
JBF
loosen the ball joint from the knuckle and coat the surfaces with grease, re-torque, and no more noise...
Old Sep 22, 2010 | 04:13 PM
^really thats it?
Old Sep 22, 2010 | 04:17 PM
JBF's Avatar
JBF
Worked on my buddy's car. And there's a thread somewhere on my350z that talks about this.
Old Sep 22, 2010 | 04:21 PM
What does SPL have to say?
Let me guess Shvt out of luck to bad..
Old Sep 22, 2010 | 04:33 PM
Deepdiver's Avatar
do you have the V1 or V2 kit?
Old Sep 23, 2010 | 01:06 AM
I have V2
What do you have Mr pharmD?
Old Sep 23, 2010 | 09:14 PM
Guess I will look this up on my350z later . I'm assuming this is a common problem ?
Old Sep 23, 2010 | 10:33 PM
alfhasg35's Avatar
i know what it is..!!!!!!!!! i have these and it made the same noise..!!!!!!!
It's the 15/16th's nut that sets the caster adjustment.. take off ur wheels and get a wrench on the nut and tighten it.. happened to me.. no one could figure it out but Darren at West End Alignment.!!!
Old Sep 23, 2010 | 10:37 PM
alfhasg35's Avatar
BTW.. first it happened on my drivers side and Darren fixed it.. then it happened on my passenger side and i fixed it..
Old Sep 25, 2010 | 02:36 AM
Mr_pharmD's Avatar
u got pix of the area u are talking about?
Old Sep 25, 2010 | 05:00 AM
alfhasg35's Avatar
There is a threaded rod to adjust caster, then there is a 15/16ths nut on each side to tighten to hold the threaded rod in place..
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
socalg35x
Aug 7, 2015 09:36 AM
Jussaku
Jul 29, 2015 11:45 AM
nascarbuff17
Jul 16, 2015 10:23 AM
