looking to switch over to bags....advice please.
Sep 28, 2010 | 09:03 AM
I have an 04 coupe with Flex's and I'm maxed out in the rear but its not low enough. I'm considering switching over to bags for moar low & adjustability. Anyone give an air bag noob some advice & tips? Trying to avoid making mistakes & over spending.
Reply 0
Sep 28, 2010 | 01:04 PM
Bump
Reply 0
Sep 28, 2010 | 01:38 PM
what kind of help are you looking for? Have you already done your own research? And why 2 of the same thread?
Reply 0
Sep 28, 2010 | 02:02 PM
Quote: what kind of help are you looking for? Have you already done your own research? And why 2 of the same thread?
My phone posted it twice by accident. I've done research but having input from people who have done it first hand helps. Which kit is good, which kit to avoid etc... how much was install, problems etc.... its the small things that count because every manufacturer claims their kit is the best bla bla bla...
Reply 0
Sep 28, 2010 | 02:08 PM
Check with Dustin at Strafe sells air zenith
Reply 0
Sep 28, 2010 | 02:11 PM
A lot of members run Universal Air, do a search for that. Haven't really seen anything negative about it. Install from the company costs about $1k. It utilizes your existing shocks, so if you have coilovers already, you can use those for better performance.
Reply 0
Sep 29, 2010 | 05:23 PM
What's your budget?
Reply 0
Sep 29, 2010 | 08:08 PM
Anybody have some really good links about bags specifically for g's or z's? I haven't checked too much over on my350z but it seems like there isn't a ton of info on here.
Reply 0
Sep 30, 2010 | 01:01 AM
I can't speak for Universal, but I recently installed a K Sport kit. It was a complete bolt on kit and was really painless to install. I spent about $2k on the kit and the good thing about it was that I didn't have to modify my stock struts to make the bags work. Here's the link to the pro kit. http://www.ksportusa.com/asp/air_sus...roduct_id=as02
There is also a basic kit which comes with 1 compressor rather than 2. The quality/ease of install all depends on your budget as stated above. Hope this helps.
Reply 0
Oct 1, 2010 | 07:20 PM
I know many that run UAS and have had no problems. But then I do know some that have had their bags leaking. I'd probably go with AirRunner for peace of mind.
Reply 0
Oct 1, 2010 | 07:49 PM
Have you tried cutting the springmount and removing one of the rings? I have tein flex also and mine is sitting pretty good after I did that.
Reply 0
Oct 1, 2010 | 08:04 PM
I'm selling my UAS kit
Reply 0
Oct 7, 2010 | 05:32 PM
Quote: Have you tried cutting the springmount and removing one of the rings? I have tein flex also and mine is sitting pretty good after I did that.
what rings?
Reply 0
Quote: I'm selling my UAS kit
g35 or g37? will it fit an 04 coupe?
PM me
Reply 0
