05 G35X Front Wheel Bearing replacement problem
Old Nov 17, 2010 | 05:48 PM
434LS3's Avatar
I am replacing a wheel bearing on 05 Infiniti G35x (awd). I can only get 3 of the 4 hub bolts off. One of the suspension linkages makes in impossible to get the 4th bolt off without disassembling the suspension linkages. The factory service manual calls for you to do that anyway, but its just a pain in the *** because its just the one bolt you cant get to.
The problem is that the FSM wants you to use a Kent-moore ball joint puller that I cant find for the life of me. It appears to be outdated, unavailable, or not for sale at all. Is there any reason a generic pickle fork shouldnt be used instead?
Also, when I go to bust the bolts on the ball joints loose, they just spin with the shank that goes into the ball joint and I cant get them off. What am I missing?
Any help greatly appreciated.
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
attarday
Jul 15, 2015 04:03 PM
