Clicking noise in front hub?
Old Dec 5, 2010 | 01:18 AM
spinn's Avatar
Been hearing a sound coming from the passenger front end that is louder than a click...more like something is rubbing against something when I'm making a left turn. I hear it mainly when I'm making a slow left turn. Sounds like a "bad CV joint", but the G is RWD. Is this a sign of the wheel bearing in the hub failing?
2003 G35 Coupe w/BC Racing Coilovers, Wilwood Front Brakes/Rotors, and 19" G-Games wheels with 106K.
Old Dec 5, 2010 | 04:03 AM
lucid215's Avatar
i would replace the bearing. thats what it sounds like to me
Old Dec 9, 2010 | 02:17 PM
spinn's Avatar
anyone else?
Old Dec 9, 2010 | 03:47 PM
irishsig's Avatar
It might be the well known "axle click" issue.
I only noticed the clicking of my axle at low speed while turning.
If it is it just needs to be relubed.
Just do a search for "axle click" there's about 25 threads on it.
https://g35driver.com/forums/g35-cou...g35-coupe.html
Old Dec 9, 2010 | 05:38 PM
spinn's Avatar
as I mentioned, it's not really a click, but more like a hard knocking sound...and it only is heard when I'm making a hard left turn. Definitely coming from passenger front side.
Old Dec 15, 2010 | 06:47 PM
vipG's Avatar
did you ever figure it out...i have the same exact problem
Old Dec 15, 2010 | 07:12 PM
spinn's Avatar
haven't had a chance to lift up the front yet, but I'm guessing it's the wheel bearing, which means replacing the front hub.
Old Dec 15, 2010 | 07:55 PM
mkvl127's Avatar
that might be a bad axle..my moms 2004 acura TL had that problem for a while and last month the whole axe like exploded stopping the wheel instantly and it shot bearing everywhere..mechanic said it was an axle and replaced it and now everything's fine
Old Dec 15, 2010 | 08:15 PM
spinn's Avatar
THx, but not sure if the TL being a FWD vs the G being RWD makes a difference. FWD would tend to have CV joints/Axle in front; RWD, axle in rear.
Old Dec 15, 2010 | 08:16 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It's either your wheel bearing or the compression rod bushing is shot.
Old Dec 15, 2010 | 08:43 PM
spinn's Avatar
compression rod...that's new to me. Is it something that can be visually inspected on the car or does it need to be removed?
Old Dec 15, 2010 | 09:11 PM
spinn's Avatar
after reading up on the compression rod issue, I don't think that's the problem that I'm describing. My rods probably do need replacement though, because I do hear squeaks pulling into a driveway, but I can live with it for now. I'm deducing that the wheel bearing is the actual problem that I'm referring to.
Old Dec 15, 2010 | 10:13 PM
There's an easy way to check your wheel bearings if you can jack up the corner you want to check. Grab the tire at the 12 and 6 o'clock position, then push/pull back and forth. If it wiggles then your wheel bearing is bad. The more it wiggles, the worse it is.
Old Dec 16, 2010 | 07:52 PM
spinn's Avatar
thx...will try that out when I get a chance this weekend.
Old Dec 16, 2010 | 10:08 PM
NightShift's Avatar
it doesn't have to have play in it to be bad. mine is bad and the sound is very noticeable over 40mph but has no play in it at all.
